Thread: CV axle tripd stuck in trans. what to do
Results 1 to 6 of 6
  1. #1 CV axle tripd stuck in trans. what to do
    GTX Level Member colindunn's Avatar
    Aurora, IL
    replacing my cv axle today and finally got it apart after going through hell to get every little thing off anyways. then i got to the axle, gave it a pull and it fell apart. everythin came off except the tripod stuck in the trans. (nothings in the tripod except some grease) now idk what to do because i cant use the pullers you can rent from a autp parts store. so im at a loss as how to get it out and i need my car so this is a problem.
  2. #2 Re: CV axle tripd stuck in trans. what to do
    Delaware, OH
    should be able to get a slide hammer wiht an attachment specifically designed to pop out cv axles. It looks like a flat large wrench head that slips around the axle. you have to give it some force but it'll pop out.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  3. #3 Re: CV axle tripd stuck in trans. what to do
    Portland Oregon
    Pry bar works on the passenger side. Driver side it helps if you have someone with a pry bar put tension on one side while you pop it out on the other
  4. #4 Re: CV axle tripd stuck in trans. what to do
    Odessa, MO
    Yeah, what these guys said. The axle has a C-clip on it the snaps into place when it goes all the way in. They can be a real bugger to get out sometimes. I usually take a long 1/2" drive extension and either put it against the back of the CV cup and hit it, or placed it between the CV cup and the transmission case and driven it in between them until it pops loose.
  5. #5 Re: CV axle tripd stuck in trans. what to do
    Donating Users
    South Deerfield, MA
    Get something against the backside of it from underneath and whack it with a hammer. It comes out a lot easier from a whack to knock the c-clip free than by pulling or prying.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  6. #6 Re: CV axle tripd stuck in trans. what to do
    If you pull or pry from a stand still, then the clip is doing it's job by holding. The C clip requires a quick application of force from a loose stand still to compress it.
  1. Possible Bad CV Axle?
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 02:47 PM
  2. Needle Bearings falling out of Driver Trans Axle
    By justlookin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2010, 07:44 AM
  3. Bad trans or axle?
    By Black18Ice in forum General Tech Discussion
    Last Post: 08-11-2009, 08:40 PM
  4. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  5. Stuck cv axle
    By brent74 in forum Off Topic Discussion
    Last Post: 08-28-2008, 11:31 PM
