the joint on the front header into the crossover, on mine it starts with a smaller diameter tube then goes slightly larger causing the crossover not to slip on all the way
Yes, get it started then do the couple turns on the bolts and tap on the header, bolt turns tap bolt turns tap method I mentioned.
