Thread: Doing a build next month.
Results 1 to 9 of 9
  1. #1 Doing a build next month.
    SE Level Member Justin48's Avatar
    Groton, CT
    Hey forum! so i got a chunk of change laying around and want to throw some in my gtp. current mods are a custom 4" fwi, speed daddy headers, and tune by prjperformance, so i need some advice if i am doing good in where i want to go with my build and if i am covering all bases and who recommends what.
    inter-cooling
    I already have bought a machined lim and prj inter cooler. i need to get the rest of the kit do you think wbs intercooler install kit is enough and do you recommend their front mount or should i go another route.
    valve train
    i was thinking zzp's xpz cam but i am unsure if i need to machine my head or does the modified retainers work and is the 130# and 150# springs overkill?
    comes with appropriate push-rods it says but what about lifters stock ok or need upgrade?
    Or should i just go with the comp xp with 105#'s?
    Obviously going to go with a double roller chain
    pulley's
    zzp mps 3.2? with above mods do i need to up my injectors?
    oversize idler pulley
    electronics/gauges
    hp tuners (I'm a noob but will have to kill some time interweb searching on what to do)
    AEM wide-band
    AEM Boost
    Aeroforce
    mic parts
    autolights 103s 180* t stat inter-cooler reservoir, belt, cam install gasket kit
    think that is all please tell me what you think i am missing or over looking THANKS!
    Autolite Spark Plugs: 103s
    Thermostat: 180*
    Cam Install Kit
    Machined Oil Pump cover
    X-P HOT Cam: w/springs, retainers, rollmaster
    Valve Seals
    HPTuners VCM Suite
    AEM Wideband o2 sensor
    Aeroforce Intercepter scan gauge
    O2 extension harness
    ZZP Modular Pulley System - Size:3.2
    Tensioner & Idler Pulleys (6rib)
    Serpentine belts
    Supercharger Pulley Puller
    ZZP Stage 2 2.25 inch core`
    Last edited by Bio248; 08-22-2010 at 10:05 AM. Reason: current parts list from zzp for the build, cleaned up your list - Bio
  2. #2 Re: Doing a build next month.
    Jan 2009
    Tallahassee, FL
    The XPZ is a great cam, you don't need any kind of machine work for the install. Stock pushrods and lifters are fine, don't use OE-Rs. 130# springs will be fine as well.
    For the double roller make sure that you get a machined oil pump cover.
    With intercooling pretty much just get the biggest FMHE that you can, looks like wbodystore covers the basics for an IC install.
    For tuning you might want to start out with something like a 3.4" pulley to get a baseline tune. The 3.2" is good for what you're wanting to go for.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Doing a build next month.
    Groton, CT
    ok well looking around ppl where saying the xpz is a wast of money if you dont have ported heads... stock lifters i have seen being widely used... and got the machined pump cover... what about the 2 cover gaskets?? doesnt that cause a leaking issue?
    oh big question injectors? do i need them and if so what size??
  4. #4 Re: Doing a build next month.
    Jan 2009
    Tallahassee, FL
    Had a brain fart, I was thinking XP lol. Get that one.
    I don't know much about any leaking issues, all I know is that you are supposed to use one with the double roller. I assume it's because the chain and gears are thicker.
    77 Morris Garage B
  5. #5 Re: Doing a build next month.
    cleaned up your mod list. looks to be pretty complete. sounds like youre ready to put down a good chunk of money all at once. as for your questions:
    a) stick with an xp, if seen people make similar power levels on an xpz after they switched from an xp. stick with 105# springs with these, just try and avoid comp springs.
    b) youll probably need bigger injectors for this setup since youll be probably running less than a 3.2 in the end. i would also suggest buying more than one pulley (like a 3.4, 3.0 too).
  6. #6 Re: Doing a build next month.
    maybe add a shift kit to your list to firm up the tranny.
    I dont know what tranny you have tho, stock or built? it just an idea.
  7. #7 Re: Doing a build next month.
    Charles City, IA
    I would go s1x cam and 105# springs, and a new stock replacement timing change set.
    SMGPFC Two Nipple General
  8. #8 Re: Doing a build next month.
    Groton, CT
    what size injectors you guys think? Hey thanks for the clean up the parts list. stock tranny btw you think a shift kit is in order instead of just tuneing-in the pressurs?
  9. #9 Re: Doing a build next month.
    Charles City, IA
    Most start at the 42.5 injectors.
  1. Donating this month all goes to charity
    By Rocket468 in forum Site/Club News
    Last Post: 08-28-2009, 11:53 PM
  2. 7 Month Progression!
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 06-04-2009, 06:49 PM
  3. 2 month wait wtf
    By 05SS45 in forum General Tech Discussion
    Last Post: 04-11-2009, 06:05 PM
  4. new to here new hu no month, year, or date now
    By decker04 in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:26 PM
  5. Any meets in OK this month?
    By Iron Indian in forum Southwest
    Last Post: 02-02-2008, 10:40 PM
