Thread: Doing a build next month.
Results 1 to 9 of 9
Threaded View
  1. #1 Doing a build next month.
    SE Level Member Justin48's Avatar
    Groton, CT
    Hey forum! so i got a chunk of change laying around and want to throw some in my gtp. current mods are a custom 4" fwi, speed daddy headers, and tune by prjperformance, so i need some advice if i am doing good in where i want to go with my build and if i am covering all bases and who recommends what.
    inter-cooling
    I already have bought a machined lim and prj inter cooler. i need to get the rest of the kit do you think wbs intercooler install kit is enough and do you recommend their front mount or should i go another route.
    valve train
    i was thinking zzp's xpz cam but i am unsure if i need to machine my head or does the modified retainers work and is the 130# and 150# springs overkill?
    comes with appropriate push-rods it says but what about lifters stock ok or need upgrade?
    Or should i just go with the comp xp with 105#'s?
    Obviously going to go with a double roller chain
    pulley's
    zzp mps 3.2? with above mods do i need to up my injectors?
    oversize idler pulley
    electronics/gauges
    hp tuners (I'm a noob but will have to kill some time interweb searching on what to do)
    AEM wide-band
    AEM Boost
    Aeroforce
    mic parts
    autolights 103s 180* t stat inter-cooler reservoir, belt, cam install gasket kit
    think that is all please tell me what you think i am missing or over looking THANKS!
    Autolite Spark Plugs: 103s
    Thermostat: 180*
    Cam Install Kit
    Machined Oil Pump cover
    X-P HOT Cam: w/springs, retainers, rollmaster
    Valve Seals
    HPTuners VCM Suite
    AEM Wideband o2 sensor
    Aeroforce Intercepter scan gauge
    O2 extension harness
    ZZP Modular Pulley System - Size:3.2
    Tensioner & Idler Pulleys (6rib)
    Serpentine belts
    Supercharger Pulley Puller
    ZZP Stage 2 2.25 inch core`
    Last edited by Bio248; 08-22-2010 at 10:05 AM. Reason: current parts list from zzp for the build, cleaned up your list - Bio
  1. Donating this month all goes to charity
    By Rocket468 in forum Site/Club News
    Last Post: 08-28-2009, 11:53 PM
  2. 7 Month Progression!
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 06-04-2009, 06:49 PM
  3. 2 month wait wtf
    By 05SS45 in forum General Tech Discussion
    Last Post: 04-11-2009, 06:05 PM
  4. new to here new hu no month, year, or date now
    By decker04 in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:26 PM
  5. Any meets in OK this month?
    By Iron Indian in forum Southwest
    Last Post: 02-02-2008, 10:40 PM
