Hey forum! so i got a chunk of change laying around and want to throw some in my gtp. current mods are a custom 4" fwi, speed daddy headers, and tune by prjperformance, so i need some advice if i am doing good in where i want to go with my build and if i am covering all bases and who recommends what.
inter-cooling
I already have bought a machined lim and prj inter cooler. i need to get the rest of the kit do you think wbs intercooler install kit is enough and do you recommend their front mount or should i go another route.
valve train
i was thinking zzp's xpz cam but i am unsure if i need to machine my head or does the modified retainers work and is the 130# and 150# springs overkill?
comes with appropriate push-rods it says but what about lifters stock ok or need upgrade?
Or should i just go with the comp xp with 105#'s?
Obviously going to go with a double roller chain
pulley's
zzp mps 3.2? with above mods do i need to up my injectors?
oversize idler pulley
electronics/gauges
hp tuners (I'm a noob but will have to kill some time interweb searching on what to do)
AEM wide-band
AEM Boost
Aeroforce
mic parts
autolights 103s 180* t stat inter-cooler reservoir, belt, cam install gasket kit
think that is all please tell me what you think i am missing or over looking THANKS!
Autolite Spark Plugs: 103s
Thermostat: 180*
Cam Install Kit
Machined Oil Pump cover
X-P HOT Cam: w/springs, retainers, rollmaster
Valve Seals
HPTuners VCM Suite
AEM Wideband o2 sensor
Aeroforce Intercepter scan gauge
O2 extension harness
ZZP Modular Pulley System - Size:3.2
Tensioner & Idler Pulleys (6rib)
Serpentine belts
Supercharger Pulley Puller
ZZP Stage 2 2.25 inch core`
