Thread: Engine misfire
Results 1 to 6 of 6
  1. #1 Re: Engine misfire
    you can turn the code to no report, so it wont set a check engine light.
    otherwise there really is no way to tune the car so it wont misfire randomly at idle when you have a cam.
  2. #2 Re: Engine misfire
    Pennsylvania
    If it's not misfiring anymore, but the code is stuck on, can't you just unhook the battery for a couple of hours so that it will clear?
  3. #3 Re: Engine misfire
    SE Level Member WindsorGP's Avatar
    Canada
    I'm just waiting to hear from Will (Overkill) to get a in car tune and resolve the problem also the gear ratio change to the right setting.
    18's inch wheels, Lowered Front & Rear B&G 1.2" springs, KYB AGX struts, K/N air filter, 8000k HI-LO, 8000k Fog HIDS, Tinted Tails. 20% tint all around
  1. 98 gtp misfire need help:(
    By mskram1 in forum General Tech Discussion
    Last Post: 02-02-2011, 01:06 PM
  2. Engine misfire
    By T Rock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2010, 03:01 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Misfire
    By munkee in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2009, 06:46 PM
  5. Engine misfire HELP!!
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 10:16 AM
