Thread: Knock Retard
Results 1 to 20 of 65
  1. #1 Re: Knock Retard
    Pennsylvania
    Quote Originally Posted by SJAndrew View Post
    if the ECM via the KS is capable of properly retarding the timing to prevent knock, then what is the issue?
    You've got it backwards. KR prevents more knocking. the PCM doesn't have ESP to know to prevent knocking from starting. You have to knock FIRST before the timing gets pulled. How the hell else would it know? For all your education, you're making yourself out to be a box of rocks. Here's a simple, chronological list of events that are happening to your car:
    1. Open throttle
    2. Knock
    3. Knock retard; Engine power decreased; Possible continued knock
    You see, every time your foot touches the petal, you knock at least once before the timing gets pulled. So, you're knocking... a few hundred times a day at least, granted that knock retard pulls enough timing to prevent more knock?
    But hell, you're right: Your unfounded assumption just might be right (unknown unknowns don't remotely make an "equation" valid [read: No.]). Unfortunately, nothing you say will make a difference to anyone else until you have proof. So, do what everyone else says: Scan it, or GTFO. Seriously, you came to us; we didn't come to you.
  2. #2 Re: Knock Retard
    Their is a ton of OWN in this thread that is all/
    subscribed
  3. #3 Re: Knock Retard
    Denver
    I've had this car since it was brand new - 13 years. I ran 92 octane for the first ~9 years of its life until I ran some 85 octane when gas skyrocketed in price. Other than the $0.80/gallon saving, there was no difference whatsoever. Mileage, performance et al all remained identical.
    The car has 124k miles on it - 20k on the new pulley.
    My assumptions aren't unfounded. Air is less dense here - about 20%. That isn't something I pulled out of my ass - it's a fact. Other than an simple assertion that I'm wrong - please, someone, give me insight as to why I'm wrong.
    The bottom line here: none of us knows for sure what's going on.
    I will scan it and find out. I'd love to know either way.
    Perhaps it's a combination of altitude, a worn out timing chain, and luck.
    What I'm disappointed in is that answers to my question are in the form of mockery and insults. I came here for information - I presented my case, and will endeavor to prove it (if nothing to myself). Your responses, for the most part, has been disappointingly negative and uninformative
    I'm sorry for wasting your (and my) time.
  4. #4 Re: Knock Retard
    Pennsylvania
    A bit more straightforward:
    My question: could I still be having "too much KR" as a result of the pulley swap but not know it because my ECM is doing the work for me?
    Or - let me put it another way: do you need a scanner to know if you're getting too much KR?
    Yes, you absolutely must scan to know if, and how much knock retard you have and where in your powerband.
    I always figured that a smaller pulley put me closer to stock at sea level.
    I figure that the rotational speed of the pulley is close to linear to its output (this is not really the case as air is compressible, but it's close).
    If the rotational speed is somewhat linearly representative to the CFM, then I'm getting back to sea level (or so).
    One question along those lines: do you monitor KR real-time (my assumption) or is it stored in the ECM?
    There's a lot of assumption here that will be fixed with a scan; when it comes to blowing up an engine, that simply won't cut it.
    nobody answered my question: do you scan as it runs in real time to monitor KR or does the scanner store its values?
    KR is monitored close to real-time. There's a delay, as I understand it.
    I ran some 85 octane ...there was no difference whatsoever. Mileage, performance et al all remained identical.
    My understanding of fuel in extreme atmospheres is lacking... perhaps someone like Reptile could point you in the right direction here.
    1. Everyone's a dick on the Internet, especially forums. It can't be helped - it's a land of chaos where children and adults mingle. If you're here, you deal with it.
    2. You've shown little in the way of your own research regarding the topic, but persist in your point. This is irritating to some of the community, because many of them have provided a lot of information to help others (which you seem to have ignored/disregarded) - many, to the detriment of their vehicles and wallets. There is a collection of generally-accepted rules-of-thumb because the combination works every time. You challenged this unprepared, and received the response you deserve for it.
  1. Knock Retard when accelerating
    By xxmattfxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2011, 06:33 PM
  2. Safe Knock Retard numbers?
    By 4boostin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 04:57 PM
  3. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  4. Knock retard question...
    By a98gtp4u in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 05:10 PM
  5. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
