Thread: Low Coolant Dummy Light
Results 1 to 17 of 17
  1. #1 Low Coolant Dummy Light
    Denver
    My 98 GTP keeps flashing the low coolant light. I've replaced the sensor, flushed the coolant, and it still keeps staying on.
    Given the fact that I know it's not low, I've just disconnected it. The temp stays a nice 180 or so (new t-stat) so I'm not worried - just annoyed.
    I want to know why it keeps coming on.
    Stuff I've checked:
    1) No oil or other contaminants in the coolant
    2) The wiring harness at the connector etc is all clean
    3) The sensor probe is clean (and has been replaced)
    4) The coolant is dexcool type
    Any ideas?
  2. #2 Re: Low Coolant Dummy Light
    Jul 2008
    sumter,south carolina
    bad wire maybe? id get that dex cool out and replace with green coolant though. dex cool is bad stuff.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Low Coolant Dummy Light
    Galien, Mi
    Bout a year ago had same problem and it had a very small leak; I think the mechanic took the cover or something like that off that covers the supercharger and found a pool of coolant. Some gaskets were leaking ( can't remember which ones) so I had them replaced and problem solved. Hope this helps.
  4. #4 Re: Low Coolant Dummy Light
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    actually its not. ive been running this in all of my gm cars... alll of them have almost 200k on em. the dex cool is designed for aluminum to keep it cooler than regular coolant. even though my l67 is cast iron my radiator and water pump are aluminum so... just a thought. but maybe its just opinionated
    2000 Daytona GTP(aka the slow fwd GTO)
  5. #5 Re: Low Coolant Dummy Light
    Denver
    Quote Originally Posted by gabsgrammy View Post
    I know for sure that the level is fine.
    When I replaced the sensor (in hopes of fixing the problem) coolant poured out of the bung where it was mounted.
  6. #6 Re: Low Coolant Dummy Light
    Jul 2008
    Quote Originally Posted by DaytonaGTP View Post
    yea and have u ever torn down a engine thats used dex cool all its life? it clogs up coolant channels... eats intake gaskets.
  7. #7 Re: Low Coolant Dummy Light
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    I disconnected mine years ago i could not get it to work right either.
    My EX wifes other car is a broom.
  8. #8 Re: Low Coolant Dummy Light
    Denver
    Quote Originally Posted by Rocket468 View Post
    It seems we're using the same "solution"
  9. #9 Re: Low Coolant Dummy Light
    Charles City, IA
    Mine is unplugged also.
    SMGPFC Two Nipple General
  10. #10 Re: Low Coolant Dummy Light
    Jersey
    my "low coolant" light comes on sometimes, didn't unplug it cuz im lazy
    16' wrx sti- stock
  11. #11 Re: Low Coolant Dummy Light
    Charles City, IA
    Mine was unplugged when I bought the car lol, then I plugged it in and started having issues.
  12. #12 Re: Low Coolant Dummy Light
    Mar 2012
    Florida
    Which sensor monitors the "low coolant" light? Mine is on all the time. I have replaced the temp sensor on the intake?
  13. #13 Re: Low Coolant Dummy Light
    Mar 2012
    Florida
    Bump back up. Where is the sensor that monitors the "low coolant" light? Thanks
  14. #14 Re: Low Coolant Dummy Light
    i believe its on the radiator its self, pass side just under the cap. i've only seen it in write ups, never messed with it myself, not yet anyways lol
    The Boss Iceman6669's Avatar
    Jun 2011
    Passenger side by the battery. On the SIDE of the radiator about 4-6" down.
    2011 F-150 Yote powered
  16. #16 Re: Low Coolant Dummy Light
    Feb 2010
    TN
    Have in my gp 302,000 miles and my venture 240,000 miles I change it every two years its been ok it does protect aluminum, problem is most people leave in in too long or just add to it never doing a full system flush with it.
  17. #17 Re: Low Coolant Dummy Light
    Feb 2010
    TN
    Quote Originally Posted by SJAndrew View Post
    Stuff I've checked:
    Any ideas?
    I got the same problem picked up a new sensor but too lazy to change it its running fine
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. coolant light
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 03:18 PM
  4. Low Coolant Light
    By Helios in forum General Tech Discussion
    Last Post: 02-19-2009, 04:13 PM
  5. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
