Thread: Another overheating question
Results 1 to 11 of 11
  1. #1 Another overheating question
    Michigan
    I've got 2004 Grand prix with the 3.8 turbo. The other day it suddenly overheated. We rplaced the thermostat and bled the system, everything worked fine for about a week. Today I noticed the temp rising whenever I slowed or stopped, but it would drop when moving. Got home, the fans weren't turning on. Unplugged the temp sensor and they kicked right on. So the question is, is the temp sensor all that should be replaced at this time?
  2. #2 Re: Another overheating question
    Charles City, IA
    Probably, also they never made an 04+ with a turbo from the factory.
    SMGPFC Two Nipple General
  3. #3 Re: Another overheating question
    Michigan
    Pardon me, I meant supercharged. Mine is 04 and stock.
    Well we replaced it and it seems to be fixed for now.
  4. #4 Re: Another overheating question
    Michigan
    Found a leak and ended up replacing those plastic elbows as well.
    So one more question, whats the best way to get the cooling fans to turn on at a lower temp? Seems like it gets pretty warm before they kick on.
  5. #5 Re: Another overheating question
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    a 180 or 160* t-stat will help you there. i'd do 180 because 160 isn't necessary for michigan weather.
  6. #6 Re: Another overheating question
    Charles City, IA
    Quote Originally Posted by noreasonwhyy View Post
    neither of those will turn the fans on sooner. You just need to get a tune to tell the pcm when to turn them on.
  7. #7 Re: Another overheating question
    Michigan
    oh my bad. i was under the impression they did.
  8. #8 Re: Another overheating question
    Michigan
    Is that a dealer issue or where would I go to get that done? Its running plenty cool as is, but it was getting up to about 3/4 on the temp gauge before the fans kicked on. No idea what the actual temp is. Since replacing everything they haven't kicked on at all unless I turn the AC on - gauge hasn't gone over 1/2 yet, but I'd like them to kick on somewhere around there I think.
  9. #9 Re: Another overheating question
    GT Level Member rolyat's Avatar
    OKC
    A dealership probably wouldn't do it for you... try finding someone around you with HPTuners.
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  10. #10 Re: Another overheating question
    Charles City, IA
    Quote Originally Posted by GTP0 View Post
    You can get a pcm from reptile on here or any of the 3800 vendors on the web.
  11. #11 Re: Another overheating question
    Charles City, IA
    no problem, everyone has to learn sometime.
  1. **overheating**
    By tmackster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:18 PM
  2. Overheating!!
    By Pogo D Klown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2009, 03:48 PM
  3. overheating
    By famouspork in forum General Tech Discussion
    Last Post: 05-27-2009, 09:22 AM
  4. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
  5. overheating
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2008, 10:18 PM
