Thread: blinking Check Engine Light
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 blinking Check Engine Light
    SE Level Member gpgtsc's Avatar
    Jun 2010
    Detroit, MI
    Hello friends,
    I have a 06 grand prix gt supercharged with 46k miles. It drives awesome, just that when i pedal to the medal, it doesnt GO like it should. the RPM stops at 3000 and goes up and down from 2800 or 3200 RPM. I can feel the engine not wanting to rev anymore and the check engine light turns on and blinks for about 5-10 times before it turns off.
    I need help please!!!
  2. #2 Re: blinking Check Engine Light
    Apr 2009
    stockton ca
    You have a bad misfire Thats gonna tear your engine up More then likely bad plug plug wire something along those lines
  3. #3 Re: blinking Check Engine Light
    Jun 2010
    Detroit, MI
    damn ur scaring me dude. i just got the car, and all plugs look fine. How can i find out exactly wats wrong? Can i connect it to a computer module or somthing?
  4. #4 Re: blinking Check Engine Light
    Jan 2009
    Tallahassee, FL
    Just replace the plugs, then the wires if it's still doing it. Chances are the previous owner never changed them since it's so new. I went through the same thing. If the plugs or wires don't do it then get it scanned.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: blinking Check Engine Light
    Delaware, OH
    Blinking SES light means a catalyst damaging fault is occurring. You can really screw things up with that. Get it to a dealership or other mechanic and have it fixed.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  6. #6 Re: blinking Check Engine Light
    Wichita
    Quote Originally Posted by benner View Post
    Yes, things can get very damaged if you don't fix the problem asap. I had the blinking light happen to me just yesterday. Tuned out a spark plug wire got knocked off. Had I no checked under the hood & looked around serious damage could have occured.
  7. #7 Re: blinking Check Engine Light
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    do the very first thing u should and give it a tune up..spark plugs and spark plug wires. ac delco...had the same thing with a 98 gtp....also the blinking ses light is a misfire...look at the old plugs and see if any of them look really white....keep note of what cylinder it came from. let us know...
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  8. #8 Re: blinking Check Engine Light
    Blinking SES isn't just from a bad cat. It COULD be a bad cat causing the misfire...most likely...its plugs and wires. Could be your MAF too...unplug it and see if it still does it.
  9. #9 Re: blinking Check Engine Light
    Jun 2010
    Detroit, MI
    I just bought the car and replaced one plug that was cut. This blinking CES light only comes on when i step HARD on the gas pedal, but if im just driving normal in the highway i can go up to 90mph w/out any problem, thats of course if I dont step hard on it.
    I will just be taking it to ASE Mechanic and have them check it out. Since i just bought the car at 44,xxx miles and it had delphi plugs, im not sure if they were recently changed but when i carfaxed it it was takin care of, because it was on a maintenance check every now and then.
    ( Are Delphi the OEM plugs for the '06 grand prix's? )
  10. #10 Re: blinking Check Engine Light
    Jan 2009
    Tallahassee, FL
    A blinking light is a misfire. At least save yourself some money and change out the plugs before spending the money for a mechanic.
    77 Morris Garage B
  11. #11 Re: blinking Check Engine Light
    Topeka, KS
    Just go to a parts store and tell them what car you have and get replacement plugs and wires. Then put them on. You will save yourself hundreds of dollars.
  12. #12 Re: blinking Check Engine Light
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by rynoman03 View Post
    And if it still does it then go to a mechanic.
    77 Morris Garage B
  13. #13 Re: blinking Check Engine Light
    Jun 2010
    Detroit, MI
    I would have done that today if it was as easy as it sounds. Unfortunatly, im not really informed about how to change these spark plugs. i know wat they are and where they are, but i can reach down to the back and the wires on the back of the engine.
  14. #14 Re: blinking Check Engine Light
    Charles City, IA
    Remove the two upper engine mounts on the front of the engine, then pull it forward with a ratchet strap.
    SMGPFC Two Nipple General
  15. #15 Re: blinking Check Engine Light
    3/8's ratchet, 3" extension and 5/8's spark plug socket will get all of them done and you dont need to disconnect anything.
  16. #16 Re: blinking Check Engine Light
    Jan 2009
    Tallahassee, FL
    You don't even need to do that. I don't even think that I use an extension on the back.
    77 Morris Garage B
  17. #17 Re: blinking Check Engine Light
    Jun 2010
    Detroit, MI
    I've never done a repair on my mar other then installing a light bulb LOL. I have a clue on what im doing but not really sure wats steps to take and how to start.
    I was thinking tomorrow morning to get it scanned FIRST, then go from there. I would really love to do it myself but i would need like detailed write which i couldnt find anywhere.
  18. #18 Re: blinking Check Engine Light
    Jun 2010
    Detroit, MI
    just to update. I got my car scanned at AutoZone, they read NO codes. There is no check engine light on and the worker said it would read no codes unless the engine light is on.
    my car drives perfectly, just only when i 'pedal to the medal' it seems to misfire, but if i punch the gas half way, it revs up pretty nicely.
    I will look more into this later because i know its not a big issue. No engine light and it only does this when i floor it. i guess i just gotta give my supercharger a break until i notice more syptoms.
  19. #19 Re: blinking Check Engine Light
    Jan 2009
    Tallahassee, FL
    Just replace the plugs and wires already lol. I don't think that having a misfire like that will set a code, only flash the light.
    77 Morris Garage B
  20. #20 Re: blinking Check Engine Light
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    pointless thread dude dont listen!!!!!!!! plugs, wires, or cat!!!!!!!!!!!!!
  1. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  2. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  3. Check engine light
    By Hawk656 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2009, 04:13 PM
  4. Blinking service engine soon light.
    By lutman123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 11:27 PM
  5. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 09-01-2008, 09:01 PM
