Thread: SD Headers install question
Results 1 to 4 of 4
  1. #1 SD Headers install question
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I currently have my car at the garage having a set of SD Headers installed. I just called the mechanic and he is almost done installing them, but he says the front header is touching directly a harness that runs underneath it and that he can't move the harness, he is planning to re use the heat shield on the stock manifolds to separate them.
    Has anyone else had this problem when installing them? How did you fix it?
    He also says that the same front header is too close, but not touching the radiator fans, can this be also an issue with the high temps melting them down?
    thanks!
  2. #2 Re: SD Headers install question
    Charles City, IA
    Have him take a picture of the harness that is hitting it.
    SMGPFC Two Nipple General
  3. #3 Re: SD Headers install question
    Starter wire? My pace****ters liked my starter wire....
  4. #4 Re: SD Headers install question
    Mexico
    It seems to be the case Matt, he says that harness goes into the starter.
  1. how to install headers
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 02-15-2010, 02:08 PM
  2. Anyone around KC, MO install headers?
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 05:28 PM
  3. FIPK install question
    By dgs02gtp in forum Introductions/Noob Questions
    Last Post: 07-31-2009, 12:04 PM
  4. Homemade FWI Install Question
    By High Rolling GTP in forum General Tech Discussion
    Last Post: 02-01-2009, 08:51 AM
  5. anyone know how to install headers?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 05:54 AM
