Thread: po171 under heavy throttle
Results 1 to 9 of 9
  1. #1 po171 under heavy throttle
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    i get the p0171 code under heavy accell wht u guys think maybe the bbv?
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: po171 under heavy throttle
    Outer Space
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: po171 under heavy throttle
    i know its a vac leak but why only under mild to
    hard accel
    Quote Originally Posted by Lawngoose View Post
    sold 97 GTP stock
  4. #4 Re: po171 under heavy throttle
    checked for vacleak and had the car on the dyno and dyno says its running rich so the set the a/f ration to 12 and im still getting same code po171 lean bank 1 wht gives and just got a p0300 random missfire could the rich condition jave foiuled my plugs
    sold 97 GTP stock
  5. #5 Re: po171 under heavy throttle
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    mine too. doin the same thing but dunno what is causing it and the car doesnt run any different. no chugging nothing. i do not have a dyno and im not sure if mine is running rich or lean .also wouldnt a vacuum leak make your car run lean????
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  6. #6 Re: po171 under heavy throttle
    The O2 readings have told the pcm to richen up the mix because it was too lean. That's why the code set.
    Find your vacuum leak and don't worry about the when, worry about the what.
  7. #7 Re: po171 under heavy throttle
    i cant seem to find a leak sprayed brake clean everywhere and nothing happend i do have egr delete and evap code deleted and car doesnt run to bad so its a very small leak all vac lines are new wht else should i check thanks also it says bank 1 so thats the front side of the enigine right
    sold 97 GTP stock
  8. #8 Re: po171 under heavy throttle
    Pennsylvania
    What do your spark plugs look like? Are they lacquered, corroded, horribly out of gap?
  9. #9 Re: po171 under heavy throttle
    well the front bank has new 103s i put in and the back bank has mt tr55s im changing today i wanted to see if there was a diff but if front bank is numer 1 then ill put tr55s back in and if rear is bank 1 ill put 103s in there
    Quote Originally Posted by SlowNA06 View Post
    sold 97 GTP stock
  1. My New LED Tails *Pic Heavy*
    By tpalmer in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
  2. Pics of the GTP+others (heavy)
    By 1998xGTP in forum Off Topic Discussion
    Last Post: 12-27-2008, 06:26 PM
  3. On behalf of SD GTP (pic heavy)
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 08-19-2008, 12:07 AM
  4. The swap-Pic heavy
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-03-2008, 12:46 AM
