Thread: Engine swap
Results 1 to 10 of 10
  1. #1 Engine swap
    SE Level Member busagtp's Avatar
    chicago
    Hey Gp world, i need another engine for my GTP Comp G, I was wondering can i replace my series III with a series II and just switch the upper half and all electronic components? I think the 2 engines are the same besides the electronic throttle control and aluminum upper half.
  2. #2 Re: Engine swap
    As long as you get a L67 bottom end...yes. The L36 bottom end is higher compression...if you have the means of tuning it though...I'd put the higher compression in there and make it run like a bat outta hell. If not...a L67 Series II will work just fine.
  3. #3 Re: Engine swap
    chicago
    by the way its an 2004
  4. #4 Re: Engine swap
    thats implied by saying you have a comp g.
  5. #5 Re: Engine swap
    Pennsylvania
    As long as you keep the compg's blower, it makes sense to me.
  6. #6 Re: Engine swap
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Unless you found an L67 for a steal, I wouldn't do it.. You can pick up a low mileage L32 for under 1k nowadays
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  7. #7 Re: Engine swap
    Quote Originally Posted by ninnyGTP View Post
    $1k is a lot for a dime a dozen motor.
  8. #8 Re: Engine swap
    Nov 2008
    Keep in mind, these are salvage yard prices. I payed 900 for both the L67 in my SE and L32 in my GTP. L67 had 80k, L32 40k. I'm sure you east coast guys have better pricing as you're in the W-body meca. What i'm trying to put out there though is the L32 is coming way down in price and more than likely you can even pick up a short block for a couple hundred bucks if indeed that's all you need.
    Lower mileage for the same price is what I mean to say
  9. #9 Re: Engine swap
    Jan 1970
    Maquoketa, Iowa
    The 04+ fuel rail is also returnless so you should be good if your swapping the top.
  10. #10 Re: Engine swap
    chicago
    Ok thx fellas, i just bought a used series 3 for $850 so imma stick with this one and just hook the old one up because it only needs bearings.
  1. engine swap
    By Wing98532 in forum Introductions/Noob Questions
    Last Post: 06-19-2010, 11:34 PM
  2. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  3. engine swap
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2009, 03:11 PM
  4. Engine Swap
    By swapthe98 in forum Engine
    Last Post: 09-26-2009, 11:41 PM
  5. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
