Thread: boost bypass valve solenoid wiring
Results 1 to 4 of 4
  1. #1 boost bypass valve solenoid wiring
    SE Level Member 97RS's Avatar
    Dec 2010
    miami fl
    i worked on most of the harness today and i herd the function of this solenoid is not to let the car build boost in reverse. i would like to wire it to a switch because my gears suck and my rpms stay high at 70 so maybe i can keep the valve fully open to save some gas on the highway (i do a ton of highway driving on the way to work). not sure witch wire needs positive and witch one needs negative. thanks
  2. #2 Re: boost bypass valve solenoid wiring
    Donating Users
    South Deerfield, MA
    Your bypass valve is open when cruising on the highway. It only closes and builds boost when you are giving it heavier throttle. The boost guage in the DIC will give you a rough idea when the bypass valve is closing to give you boost.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: boost bypass valve solenoid wiring
    GTX Level Member real diehl's Avatar
    Salina, KS
    I think you should leave it alone
    signature removed for inappropriate content.
    -bio
  4. #4 Re: boost bypass valve solenoid wiring
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    GM wired that way for a reason...leave it alone.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. Boost Bypass Valve is it the same as a BOV?
    By xsvtank in forum General Tech Discussion
    Last Post: 08-06-2010, 12:12 PM
  2. how do i check my boost bypass valve?
    By bluevet03 in forum General Tech Discussion
    Last Post: 04-26-2010, 01:30 PM
  3. Boost Bypass Valve help
    By mikeh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2009, 01:20 AM
  4. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
