Thread: Low boost! 10 PSI on a 3.0
Results 1 to 20 of 20
  1. #1 Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    Ive been chasing a low boost problem for a while now, and ive checked everything from vac leaks to gauge problems to egr problems. I checked everything that i thought it could possibly be and after finding nothing i decided that it had to be the super charger. I had my supercharger ported and i thought that maybe something happened to it during porting that was making it unable to make boost. So i finally bit the bullet and bought a supercharger that i knew was making boost. I put it on with the 3.0 pulley still attached and im still only making around 10 psi of boost.
    Any suggestions on what to check would be very appreciated, even something off the wall that could be going on would be helpful. im at at dead end atm. I have a tech2 scanner as well that ive been using to monitor KR and alot of other data. I have 0 KR with the 3.0 making 10 psi.
    Setup is a s1x cam, speed daddy headers, ported heads, and all other supporting mods, plugs, wires ect.
    -Something else that is worth mentioning though is that i have my lower intake machined for an IC and im not running one. Im not sure if that could effect boost or not.
  2. #2 Re: Low boost! 10 PSI on a 3.0
    Portland Oregon
    I think you're fine. When you cam it, things flow so well that boost looks low.
  3. #3 Re: Low boost! 10 PSI on a 3.0
    Jan 2009
    Tallahassee, FL
    I'd say that you're fine as well. With those mods your motor will flow plenty of air.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: Low boost! 10 PSI on a 3.0
    Banned - Busted For Scamming
    Feb 2009
    I told you there was nothing wrong with that supercharger and that flowing that well would make boost low. If you are making good power what does a boost number mean?
  5. #5 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    Because im not making the power i should be, it runs strong but it only ran a 14.09 at 98 with a 2.21 60 in the 1/4. And Im pretty sure i could run a 2.8 pulley and run 12 psi with no problems. That dosn't seem right to me.
    Trans has 3.29 gears also, so for the setup i have not being able to spin the tires at all when i punch it going 20mph im lacking power somewhere. Timing tables are stock and at WOT its not pulling timing, so its not a timing issue or torque management issue.
  6. #6 Re: Low boost! 10 PSI on a 3.0
    Did you know zoomers car that makes ~450 WHP with a Gen V M90 also makes 10 PSI?
    Your 60 is quite high. Work on that.
    http://www.grandprixforums.net/timeslips.php
    98 mph trap speed seems low though.
    How much timing are you running?
  7. #7 Re: Low boost! 10 PSI on a 3.0
    Donating Users shawn's Avatar
    rogers arkansas
    wow... That's horrible times with a cam setup.. I was in 13s with a 3.4 setup with jus headers.. Smethns wrong smewhere .. Not sure if it's ur boost though bc boost sounds about rite. Zzp said xpz setup runnin a 2.6 made like 13psi.. But I don't know much bout how much boost per pulley sizes ... Jus know you should run way quicker than 14s..
    STOLEN XPZ SETUP WITH CNC PORTED HEADS!!
    13.76@99.60 on 3.4 setup
  8. #8 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    Yeah the car just seems like it isnt making the power it should be, like i said if i floor it going any faster then an idle it dosnt spin the tires at all. Ill drive it and check timing again to give you exact timing numbers but i think i remember seeing 15-16 degrees at wot. What ever stock timing is.
    Ive checked around and it seems like people who are cammed with headers are running around 10-12 psi with 3.2 pulley and some can run a 3.1 with a good tune. I just have a standard tune though and my stock injectors arent even closed to maxed, only seeing around 17.xx MS on inj pulse width.
  9. #9 Re: Low boost! 10 PSI on a 3.0
    3.0" on stock injectors? IMO, that's kinda pushing it pretty good...infact...it should run out of gas on a 3.2"/3.1"...but who knows. Sounds like your tune isn't worth a damn...I ran a 13.4 on a 3.4"/headers/XP/stock TB and a base DHP bin file with the P0300 removed...sitting on like 9psi with a 2.0 60 foot
  10. #10 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    If i was making the boost i should be with a 3.0 then yeah my injectors would be maxed. But like i said im only seeing 17.xx MS on inj pulse width and from what you told me and what others have said im good until at least 21 MS. Even then it shouldnt matter unless im going lean enough to knock, and i have 0 KR. The previdous owner of my car went 13.7 with a 3.4 setup, i dont know his 60 or MPH tho. So i know that something is up with my car, and i could blame it on the tune, but that dosnt explain the boost thing.
    So still no suggestions on what it could be?
  11. #11 Re: Low boost! 10 PSI on a 3.0
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    When i had my set up i ran a 2.6" daily and my boost avg around 10psi. Once you get air flow boost is low.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  12. #12 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    so with my only real mods being s1x cam, headers, and ported heads i thought running a 2.8 would be pretty much unheard of. I thought a 3.0 was really pushing it. Usually people running under a 3.2 have a cam and IC or atleast an IC. Well, im not quite sure what to do atm, i guess ill just run it as is and try and crank the timing as much as possible. It just dosnt make sense to me that my injecors arent closed to maxed. Has anyone ever heard of someone running a 2.8 on stock injectors? seems crazy.
  13. #13 Re: Low boost! 10 PSI on a 3.0
    the key to this is ported heads. those make a world of difference.
  14. #14 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    That is true, and i did spend alot of time on the heads and did a ton of research before i ported them. The car still has a lack of power even tho it runs well.
  15. #15 Re: Low boost! 10 PSI on a 3.0
    Apr 2009
    stockton ca
    as far as boost psi your fine But somethings wrong with your tune more then likely doesnt seem right my cars faster then th=at with a 3.4 on stock manis and s1x my heads are ported aswell
  16. #16 Re: Low boost! 10 PSI on a 3.0
    Jul 2010
    Kentucky
    I dont know ifthis is your problem but my bbv was messed up on my car and was only runing about half boost i fixed it and now boost gauge is maxed out check your bbv
  17. #17 Re: Low boost! 10 PSI on a 3.0
    that typically leaves you with 4-5 psi, not 10.
  18. #18 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    yeah, and when i was low on boost that was the first thing i went to and i was convinced that it was the problem somehow. Even with it disabled boost dosnt change.
  19. #19 Re: Low boost! 10 PSI on a 3.0
    Feb 2010
    indiana
    Im also only getting 13 mpg, but i dont think im running that rich. where should my o2s be? I have both my o2 sensors working but i have no cat. Could this be causing a problem?
  20. #20 Re: Low boost! 10 PSI on a 3.0
    SE Level Member kirkkarem1212's Avatar
    waterford, MI
    ok guys, i have a simaler problem. 15 psi at a 5200 rpm shift and 17-20 at a 5700 rpm shift. intense stage 1 cam, headers, no cat, ect. i need helpp.
    http://www.grandprixforums.net/20-psi-boost-35377.html
    3.4 pulley, Borla Cat-Back, Headers, 3" Downpipe, Cat Del, Volt Booster, Trasher Air Box, K&N Filter, Intense Stage 1 Cam, 105# springs, Powder Coated TB, S/C, And Fuel Rails.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. Low boost
    By jtemple54 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 03:21 PM
  4. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
