Thread: Need some help from the pro's
Results 1 to 20 of 26
  1. #1 Need some help from the pro's
    Jul 2010
    Kentucky
    Hi guys im new to this sight but not new to working on cars and bikes. I signed up to this forum for some helpful info. Here's the deal. I have a 99 grand prix gt that i have been having problems with the motor. Its been getting water in the intake its making a puddle above my heads laying in the lower intake and causing my car to try to run on water lol. So i changed upper and lower intake gaskets and tb gasket. It still does it. When u rev the motor it collapses my radiator hoses and fills my motor with water. Everyone keeps saying head gaskets but if were that then how is there water sitting above the heads in the intake. Well here is what iv decided to do. I found a 3.8 super charged motor and hae decided to put that in. I know i have to have the ecu and wiring harness, but here is my question. My car is a 4 door with all options and the car im getting the motor and ecu out of is a 2 door gtp. My question is will a 2 door ecu work on a 4 door correctly, and still let all of my windows and etc. to work? Also will i have to get the ecu reflashed or redone to work on my car or can i just plug and play and have no problems? I need a 100% correct answer not just people guessing this is my daily driver and i dont need a piece of garbage thats just gonna break down. Any help is appreciated
  2. #2 Re: Need some help from the pro's
    Jul 2008
    sumter,south carolina
    what year is the donor car?
    02 GTP with mods 05 GP for DD
  3. #3 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    2000 i just wana know what all im going to need and if im going to run into any problems
  4. #4 Re: Need some help from the pro's
    Jul 2008
    its a straight swap... id get it tuned afterwards to keep 3.29 gearing. harness...pcm... motor. all u need.
  5. #5 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    What do you mean 3.29 gearing? What about the computer with it coming from a 2 door going into the 4 door? Does it have to be reflashed for my vin to work properly? I wana mae sure my power windows and keyless entry still work. I shouldnt need a tune if its just a straight swap should i
  6. #6 Re: Need some help from the pro's
    Jersey
    your still using the gt trans, it has 3.29 vs gtp trans with 2.93 gear ratio. So either way your still going to have to take the gtp pcm and flash changes for 3.29 gearing . Your power windows etc etc will work just fine.
    16' wrx sti- stock
  7. #7 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    Why do u have to flash the ecu for gearing isnt it vacuum operated? Can i get it flashed at the dealer?
  8. #8 Re: Need some help from the pro's
    Charles City, IA
    The final drive ratio is different. Your tires will be spinning at a different speed than what the computer thinks they should and it will cause lots of issues. I do not think a dealer can change the final drive ratio in the pcm. You just need to get an aftermarket pcm from one of the 3800 vendors.
    SMGPFC Two Nipple General
  9. #9 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    how much will that cost and will it have to be dyno tuned after that?
  10. #10 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    And if i dont do the thing with the computer what will my car be doing? Will it still drive or not?
  11. #11 Re: Need some help from the pro's
    Jul 2008
    only 97 trans is vac controlled. u dont need a dyno tune. u can order one from many of the vendors. or just get reptile "site vendor" to do it for u. just send him the pcm.
  12. #12 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    Should the car still run and drive without that though?and How much does he charge and how long does it take?
  13. #13 Re: Need some help from the pro's
    Jul 2008
    tunes for 50... mine had a pretty fast turn around time. not sure about how it will run.. ive never actually done a gt to gtp swap.
  14. #14 Re: Need some help from the pro's
    Charles City, IA
    Your car will not be drivable. It will idle, but it will not shift. You will not need a dyno tune.
  15. #15 Re: Need some help from the pro's
    Jersey
    hell, anyone with a tuner can do it for you, you just need to make sure they have an off-board adapter.
    I have an off-board adapter, i would do it for you, only if i knew how to use it
    16' wrx sti- stock
  16. #16 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    Quote Originally Posted by 99prixgt View Post
    lol you would have to know how to use it. do you think anyone has one of these for sale already done? or is it to rare of a swap for anyone to have it? can i get my gt computer done like this or does it have to be a gtp computer? also yall say it wont shift when driving would i beable to **** it manually until i get my ecu done for the swap? im trying to make this easy as possible. also will i have any problems running my factory fuel pump with the motor swap?
  17. #17 Re: Need some help from the pro's
    Charles City, IA
    ok, IT WILL NOT DRIVE AT ALL WITH OUT THE CORRECT TRANS TUNE
    step 1. find reptile on this site
    step 2. pm him saying you just put a l67 in your gt
    step 3. send him your pcm
    step 4. receive your pcm
    step 5. drive your car
  18. #18 Re: Need some help from the pro's
    Jul 2008
    ^ that.... not as hard as ur makin it out to be. http://www.grandprixforums.net/5-reptile/ made it even easier
  19. #19 Re: Need some help from the pro's
    Jersey
    in all seriousness, your task is so simple either contact reptile, or even find a local with a tuner, the job is about 15 minutes worth of work.
    Btw manual shifting an automatic car will leave you with a red ass, its full of fail and destruction.
    16' wrx sti- stock
  20. #20 Re: Need some help from the pro's
    Jul 2010
    Kentucky
    how do you tune it yourself? what do you do and what kind of tuner do you need?
pro
