I don't need dyno sheets to tell me what the ~30 degree change in my IAT's (vs stock airbox/stock IAT) already show. and that ~30* is cruise IAT, not in town. every 10* is said to be ~1-2hp depending on other conditions and timing tables. if the 2 intakes flow enough for the given level of mods (on a NA car) the colder one will produce more power at the same AFR. period.
Now if my AFR has changed (and i bet it has) that is another variable. my STFT and LTFT are pretty close to 0 however (within 2% usually at WOT) so i'll assume the car has already learned any applicable adjustments.
