EDIT: And yes, I have used the search! There are a few topics about flushes, but the information is very jumbled and non-informative!
well, 180k miles later, the coolant has become so rusty it's turned into a jelly substance. it clogged and blew the head gaskets, blew the thermostat, cracked the heater core, and became too much for the water pump to handle.
i just finished rebuilding the motor, alongside some new mods.
CAI
3.5" pulley
autolite 104s
autolite 8mm plugs
180* tstat
speed daddy headers
custom-tuned PCM
preventative maintenance is complete, including fuel, oil, and trans filter, etc.
some asshat stabbed my tires last year just as the head gasket went out, which REALLY discouraged my love for GTPs. i tried selling it, but then changed my mind and decided to tackle it head-on and get it done.
now i've got some new tires and have made some interior modifications, but the overheating problem still exists! (i figured i'd give a little background. :P) i will admit, being able to test-drive for two minutes gives me many oohs and ahhs thrills, but i'd like it to last much longer.
i work at autozone and decided to buy some prestone super radiator flush. it's about a quart i believe of some supposed super-powered sodium-silicate. i've been reading up on guides to flush for a while now, but now that i have the flush kit, coolant, and solvent, i'm stuck.
i can't find the draincock on our radiators. i've seen pictures of new radiators with what appears to be a drain plug on each side, but i'm unsure. i've looked all over under the car and i've seen a rubber plug on each side, but i have no idea how to open those suckers up. am i looking in the right place?
next, what is the most efficient way to flush these darn things? i keep reading confusing guides with hose tees and splash deflectors (which i have), but they're generic guides and not for 3800s.
do i want to run the solvent and fill with water to flush, then run 50/50 green coolant and green full-strength antifreeze when i finally refill? note i say green coolant because i will never go back to dex-cool. i know some of you defend it, but working in a semi-automotive retail environment, i've seen the effects of dex-cool on MANY W-bodies from customers that come to our store.
thanks for the help guys. this is the one last thing keeping my car from being on the road. i've been working on it for 8 months, slowly adding to it and changing things, making fixes. it was a total piece of sh*t when i bought it. i can't wait to hear her scream now!
