Thread: Removing A/C Compressor
Results 1 to 13 of 13
  1. #1 Re: Removing A/C Compressor
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    if your compressor went, you might have metal shavings in your lines, as well as blocking your orifice tube. a/c is the one thing i won't do myself, i'd rather sweat with the wind blowing than run around an a/c system fixing problem after problem.
    my advice is to take it to a shop if you aren't experienced.
  2. #2 Re: Removing A/C Compressor
    Edmond
    Replacing the a/c compressor is a rather simple process, but it just is somewhat time consuming from beginning to end. After removing the accessory belt, the a/c lines and then the compressor. You have to replace the compressor, the a/c lines, the accessory belt and then refill your system.
  1. AC Compressor
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 12:04 PM
  2. AC Compressor
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2009, 02:56 PM
  3. How big of a compressor should I get?
    By FuglyGTP in forum Off Topic Discussion
    Last Post: 03-06-2009, 08:18 PM
  4. Bad AC compressor??
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2008, 07:06 PM
