Thread: Speed Daddy Headers...Ticking...
Results 1 to 20 of 23
  1. #1 Speed Daddy Headers...Ticking...
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I just installed my Speed Daddy headers, and I'm getting a really annoying ticking noise under acceleration. What should I do? I'm so fed up with this install. It has taken forever and has given me nothing but problems. I've heard the flex pipe in these headers can be the cause, but I've also heard of people installing them with zero problems. Could it be an exhaust leak?
  2. #2 Re: Speed Daddy Headers...Ticking...
    No one can tell you for sure since we can't come and inspect your install.
    video
  3. #3 Re: Speed Daddy Headers...Ticking...
    Charles City, IA
    Its probally the flex that is ticking. Replace it with a flex from zzp.
    SMGPFC Two Nipple General
  4. #4 Re: Speed Daddy Headers...Ticking...
    New Jersey
    Its an exhaust leak. I always thought it was my Y-Pipe but I never really cared to fix it. I didnt know the flex pipe was already a known problem. Hopefully its fixed after I change mine out.
  5. #5 Re: Speed Daddy Headers...Ticking...
  6. #6 Re: Speed Daddy Headers...Ticking...
    Jul 2008
    sumter,south carolina
    header wrap? muffler wrap? i was thinking about that but didnt know if it would seal it up good. i have a leak there that keeps getting worse daily.
    02 GTP with mods 05 GP for DD
  7. #7 Re: Speed Daddy Headers...Ticking...
  8. #8 Re: Speed Daddy Headers...Ticking...
    header wrap, the DEI stuff.
    I bought some Thermotech stuff. Just waiting for my exahust to cool off. We'll see how it goes.
  9. #9 Re: Speed Daddy Headers...Ticking...
    Header wrap didn't do a damn thing. ****.
  10. #10 Re: Speed Daddy Headers...Ticking...
    Jul 2008
    Quote Originally Posted by Bedwards View Post
    x2
  11. #11 Re: Speed Daddy Headers...Ticking...
    Put band clamps on the slip joints. Didn't help at all. Wasted way too much money today.
  12. #12 Re: Speed Daddy Headers...Ticking...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You sure the leak isn't from one of the slip joints? The flex is known to tick, but any leak in the slip joints will give you a tick as well.
    You DID throw out the stock clamps and put on band clamps + copper RTV, right?
    2001 Buick Regal LS - Almost Stock
  13. #13 Re: Speed Daddy Headers...Ticking...
    Quote Originally Posted by Scimmia View Post
    I'm going to buy band clamps right now.
  14. #14 Re: Speed Daddy Headers...Ticking...
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    minesomehow flexed with the flex pipe and my exaust was hitting the back of where it mounts by the bumper, i bent the hangers a lil and its ok now, other than that the speed daddy headers were great, with band clamps from napa. very small exaust leak at the flange, when warm its gone.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  15. #15 Re: Speed Daddy Headers...Ticking...
    Gonna try adjust the headers tonight and re-tighten all the bolts to see if anything is loose. I doubt it though.
  16. #16 Re: Speed Daddy Headers...Ticking...
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you need to use copper RTV on the slips
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  17. #17 Re: Speed Daddy Headers...Ticking...
    Quote Originally Posted by 01gpgt01 View Post
    I did.
  18. #18 Re: Speed Daddy Headers...Ticking...
    Jul 2008
    have u narrowed ur leak down at all? my flex had a slight tick to it... header wrap didnt do ****... muffler wrap from o reillys did.. its called tiger something, i forget. still have a small leak on back side of crossover which still has u bolt clamp. plan to tackle that this weekend. im just gonna wrap that same muffler wrap around the joint and band clamp it. tired of dealing with these leaks... went from leak free to 2 leaks in a matter of months.
  19. #19 Re: Speed Daddy Headers...Ticking...
    It's hard to narrow it down, because I can really only hear it when I'm driving.
    P.S. Getting a band clamp on the bottom part of the crossover is a HUGE *****. You will definetely need 2 people to do it, and it takes a lot of maneuvering.
  20. #20 Re: Speed Daddy Headers...Ticking...
    Donating Users kfish's Avatar
    Ohio
    if you put the clamp on the rear header THEN put the crossover in and tighten it its very easy. its hard to put on with the crossover already in though.
  1. Speed Daddy Headers
    By ctrout in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2011, 10:37 PM
  2. Speed daddy headers installed.
    By EricGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 03:45 PM
  3. Speed Daddy Headers
    By Advan22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2010, 12:06 AM
  4. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
  5. what happened to the speed daddy headers?
    By skidoojames151 in forum General Tech Discussion
    Last Post: 02-20-2010, 11:05 AM
