Thread: What vin 1 engines.....
Results 1 to 7 of 7
  1. #1 What vin 1 engines.....
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I was wondering what other l67 vin 1 engines can swap right into my car other than impala/monte carlo? Thanks.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: What vin 1 engines.....
    any 3800 series II or series II.
    I take it you want supercharged? If so, L67 or L32.
    They will work... Depending on the things you wanna change.
  3. #3 Re: What vin 1 engines.....
    Bowie, MD
    I dont wanna change anything at all. Just want another l67 engine to go in place of my current dead one. I found a cheap engine from a 1998 Buick park avenue and wondering if it will just bolt on my impala.
  4. #4 Re: What vin 1 engines.....
    your impala never had an L67 in it... so the flex plate wont have the correct mounting bolts for your torque converter unless you already swapped the transmission and/or torque converter over the first time you did it.
    Your car domain is funny...
  5. #5 Re: What vin 1 engines.....
    Bowie, MD
    Lol thanks. Yes i already swapped in the hd transmission when i did the swap. Full swap from a 2004 impala ss.
  6. #6 Re: What vin 1 engines.....
    I would think that would be okay then, its gonna be a series II but the belt routing is going to be different for the S/C which means you'll need a different belt.
  7. #7 Re: What vin 1 engines.....
    Bowie, MD
    Thanks matt.
  1. 3800 not supercharged engines
    By RyanL in forum General Tech Discussion
    Last Post: 06-06-2010, 08:22 AM
  2. For the ones with top swapped engines.
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2010, 01:18 AM
  3. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
  4. Jasper Engines....anyone know anything about them?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 08-13-2008, 04:23 PM
  5. Some bling for these engines...
    By GR8racingfool in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2008, 10:13 PM
