Thread: Header hitting sway bar and power steering lines
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Header hitting sway bar and power steering lines
    Florida
    Well, the headers werent touching anything anymore, and then engine didnt jerk around under hard breaking/acceleration. Stuff like that.
  2. #22 Re: Header hitting sway bar and power steering lines
    Portland Oregon
    Yea, the solid one was an improvement but didn't turn out to be a long term solution.
  3. #23 Re: Header hitting sway bar and power steering lines
    Portland Oregon
    Because nobody makes them, I've decided to construct my own poly-urethane motor mount (the under the motor mount).
    Step 1 - Get a stock fluid filled motor mount.
    Step 2 - Cut the corners out, drain the fluid, and clean insides with some carb-cleaner or something of the sort.
    Step 3 - Acquire 1 pound of Shore 94 urethane, mix, and pour
    Step 4 - Let cure for 7 days. Install and enjoy!
    Here ya go!
    I got the urethane from mcmaster.com It was shore 94 hardness. Harder than ZZP's poly under motor mounts.
  4. #24 Re: Header hitting sway bar and power steering lines
    Jul 2008
    nj
    I did the same thing with my lower motor mount. Solid to this day
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  5. #25 Re: Header hitting sway bar and power steering lines
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    i ended up buying one from oreillys. its a solid one. I will do this with a hydraulic one after i order all the stuff. but i needed one right away so i had to get it.
    The one that was in there was completely toast. After getting this one in there the motor still barely and i mean minute, leans still. It might just even be my eyes are used to seeing it lean that way but in reality it isnt. who knows. tranny mount is the next step.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  6. #26 Re: Header hitting sway bar and power steering lines
    Trans mount should fix it especially if isn't in 100% condition IMO.
  7. #27 Re: Header hitting sway bar and power steering lines
    Portland Oregon
    Forgot to mention... One of the fastest S/C'd Buick Regal is using this type of motor mount with no issues. He's the one that told me about how to make it.
  8. #28 Re: Header hitting sway bar and power steering lines
    Topeka, KS
    Cool Idea.
  9. #29 Re: Header hitting sway bar and power steering lines
    is the transmission mount a hydraulic mount as well? if so, what about cutting the sides out of that and making it a poly mount?
  10. #30 Re: Header hitting sway bar and power steering lines
    i forsee no knock or false knock i should say. got my new poly dog bone mounts in today and wow this engine doesnt move any where. no movement what so ever. Had a bad exhaust leak. the dp gasket was toast. also flipped the sway bar and have about an inch clearance now and about an 1/2 an inch clearanence from the power steeering lines.
  11. #31 Re: Header hitting sway bar and power steering lines
    Portland Oregon
    I don't know about the tranny mount. Never tried one but I imagine the concept is the same.
  12. #32 Re: Header hitting sway bar and power steering lines
    Jul 2008
    sumter,south carolina
    trans mounts are hydraulic
    02 GTP with mods 05 GP for DD
  13. #33 Re: Header hitting sway bar and power steering lines
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Quote Originally Posted by bbptech View Post
    I've got some crazy clunking going on and I think it's my control arm bushings. I have a set of new moog arms waiting to go on and I really want to flip my sway bar while I'm at it. I was checking it out the other day and it definitely looks like it's hitting/rubbing the flex pipe because I can see a little damage there.
    How hard was it to flip and is there a write-up anywhere?
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  14. #34 Re: Header hitting sway bar and power steering lines
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    what is the benefit of flipping your sway bar, besides the above obvious of it not hitting/ rubbing on things. would you lose any performance in the suspension or gain?
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  15. #35 Re: Header hitting sway bar and power steering lines
    Antioch, IL
    Is this 1lb enough for one mount, or can I get 2 mounts done?
    2009 Challenger SRT8
    Expert at being gay.
  1. power steering?
    By X97prixX in forum General Tech Discussion
    Last Post: 01-14-2010, 04:02 PM
  2. Power Steering
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2009, 11:51 PM
  3. Front Upgraded sway bar hitting.....
    By I4NI in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2009, 10:20 AM
  4. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
