Thread: MAP Sensor just hanging
Results 1 to 4 of 4
  1. #1 MAP Sensor just hanging
    Tweed, ON
    I was looking over the engine on my 1999 GTP the other day and noticed that someone who owned it before me was all over this engine.
    One thing that I didn't like was the fact that the MAF sensor was just hanging behind the engine almost sitting on the exhaust manifold.
    I cant for the life of me figure out where it used to sit or where its factory attached.
    If anyone has a picture of where its suppost to be or can describe it to me, I would be very happy.
    Thanks.
  2. #2 Re: MAP Sensor just hanging
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Machzzzz1 View Post
    Thanks.
    There is a metal bracket it sits on. Most remove it to have easier access at the rear bank. I would either find the bracket or zip tie it in a better place. As long as the line is not cracked or the wires are not burnt, it's pretty bullet proof.
  3. #3 Re: MAP Sensor just hanging
    Dec 2008
    michigan
    that is your MAP not MAF. MAF connects to a vacuum line, MAP connects to air intake pre-TB.
  4. #4 Re: MAP Sensor just hanging
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by explokid View Post
    Manifold Absolute Pressure Sensor
    Mass AirFlow Sensor
    Corrected:
    you are correct, that is your MAP sensor hanging. MAP connects to a vacuum line, MAF meters air pre-TB.
  1. Front Splash guard hanging?
    By TheMexican in forum General Tech Discussion
    Last Post: 03-18-2010, 09:35 PM
  2. i have a sensor hanging from tire
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-29-2009, 05:59 PM
  3. hanging mufflers
    By 04GrandPrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2009, 01:46 AM
  4. Slightly Hanging Rear Right Caliper
    By JoshMcMadMac in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2009, 05:52 PM
  5. Low hanging exhaust...please help
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 01:11 AM
