Thread: 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
Results 1 to 20 of 38
  1. #1 Re: 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    Jul 2008
    sumter,south carolina
    drive the car at night... look under the car when u get done, somewhere where there isnt much light and see if the cat is glowing.
    02 GTP with mods 05 GP for DD
  2. #2 Re: 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    Jun 2010
    Windsor, ON
    OK, will do BUT if it is a clogged/bad cat, wouldn't it run ****ty right off the start? Wouldn't the excess backpressure affect the entire engine as opposed to just the rear bank? Does the flow of exhaust become increasingly impeded as the cat rises in tempurature?
    I'm in no way dismissing your theory gtpinsc, I appreciate your feedback man, I've got an infrared thermometer, I'll take a reading of the cat as soon as I shut her down when I get home from work tomorrow...
  1. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  2. Replies: 8
    Last Post: 01-24-2010, 02:53 AM
  3. Bad rear 02 sensor and random misfires. Can runs just fine.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2009, 04:41 PM
  4. Car runs fine but doesn't start the first time i turn the key.. Needs a few turns..
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 02:18 AM
  5. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
