Thread: 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
Results 1 to 20 of 38
  1. #1 Re: 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Cat-less 3" dp = WIN
    5 YEARS??????
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  2. #2 Re: 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    Jun 2010
    Windsor, ON
    Quote Originally Posted by 98GTPCALGARY View Post
    5 YEARS??????
    I'd love to go cat-less but here in Ontario we have to get emission tested every other year to get plate tags, what is the OEM diameter? 2 inch? If I go 3" I'm guessing I'd have to replace everything from the cat back?
  1. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  2. Replies: 8
    Last Post: 01-24-2010, 02:53 AM
  3. Bad rear 02 sensor and random misfires. Can runs just fine.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2009, 04:41 PM
  4. Car runs fine but doesn't start the first time i turn the key.. Needs a few turns..
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 02:18 AM
  5. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
