I know this is a crazy question but i was just curious, what would happen if an l36 pcm was used in an l67 engine swap?
No an l67 engine with an l36 bin.
besides your PCM not knowing what to do with the boost, not being able to control the boost bypass valve, the wrong gear ratio in the trans files, the wrong injector sizing, the excessive WOT timing you'll be running, etc...?
a lot. how is the car even running?
Could it some how mess up the l67 engine internally?
Yeah, it certainly could. The excessive timing could very well blow a piston, and the fueling is doing god knows what with faulty MAF and MAP readings and injectors the wrong size.
Awesome.
Wow. This is good info. Thanks guys.
1 more question.
If a rod or piston is thrown or damaged, what part of another used engine should i get to fix the damaged engine?
To do any serious damage, you would have had to have driven it fairly hard. As badly as that thing had to be running, I hope you didn't do that. Thinking back, since you had the L36 TB on there, your MAF calibration would have been right. This means the only MAJOR problem with it even running was the injectors. You were running incredibly rich. This won't usually destroy the engine, although it'll do in the plugs, cat, O2 sensor, etc.
Did you happen to notice any fuel pouring out the tailpipe?![]()
No but i was misfiring on cylinder 6 and had 3 codes.
1. p0306 - cylinder 6 misfire
2. p0036 - H02s heater control circuit
3. p0449 - evaporative emissions system vent valley solenoid circuit.
whats up with all this l36 stuff on a l67 tb pcm they just dont work for a l67
get the L67 TB, the L36 is stupid especially for the inlet of the blower.
DO IT RIGHT OR NOT AT ALL!
