Thread: 2000 GTP coolant leak question
Results 1 to 7 of 7
  1. #1 2000 GTP coolant leak question
    Mar 2013
    AZ
    Hey guys, I noticed I had a coolant leak so I went to investigate. I found my elbow(s) are leaking for sure, but I wanted to know what that T fitting thing is above the front elbow. I have coolant dripping from it. At least that's what it looks like to me. Any help would be greatly appreciated. I haven't done anything to this other than a CAI, and a new thermostat (just some autozone one) about 4 months ago. She's got 101k miles on it too.
    Here's the best pic I could get of it... http://i.imgur.com/d1angoE.jpg
    Thanks for your time guys.
    I'm a noob with cars sorry :/
  2. #2 Re: 2000 GTP coolant leak question
    Max Cook
    Guest
    Thats a vac line and shouldnt have any coolant in it..
  3. #3 Re: 2000 GTP coolant leak question
    Mar 2013
    AZ
    Well ****... unless the elbow is cracked maybe up top? Can I just pull the vac line out and see if anything comes out?
  4. #4 Re: 2000 GTP coolant leak question
    Max Cook
    Guest
    Quote Originally Posted by kamuletoe View Post
    Yes. In theory nothing should come out. It wouldnt hurt to replace it either, as well as check for cracks in any of the vac lines. You can get the full vac line kit with a brass T for like $20 or something I think from ZZP.
    I mean when the elbow broke it probably sprayed coolant all over places.
  5. #5 Re: 2000 GTP coolant leak question
    Mar 2013
    AZ
    Awesome! I just checked the vac line, nothing came out and seemed bone dry. The vac line was cracked and broken where it connects to the engine. Is it ok to drive it around with it cracked? I placed it back on the nipple sticking out from the block. Thank you so much for your help man I really appreciate it.
  6. #6 Re: 2000 GTP coolant leak question
    Max Cook
    Guest
    Well I mean its a vac leak. So its not really okay. It wont run great and I wouldn't go WOT with it until you replace it, but it will be okay to drive for awhile.
    ZZPerformance - Vacuum Line Kit #ZZ-VACLK-38
    Im sure you could find the stuff locally too. Its essentially just the T's and some tubing you can cut to size. Its very common for the stock vac lines to crack and break over time.
  7. #7 Re: 2000 GTP coolant leak question
    go to advance auto, they sell small white vac T's. a pair for 2 bucks, then get 4 inches of vac tubing. then cut that 4 inch piece into 3 equal parts, toss the old T, then put the new T with each end with a vac tubing on it its place push it on the stem on the manifold, then push the stock lines into the vac lines on the new T.
  1. 2000 Grand Prix coolant leak
    By Rjsleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-03-2013, 12:04 PM
  2. Coolant leak behind power steering box - 2000 Grand Prix V8
    By wcoughlin in forum Introductions/Noob Questions
    Last Post: 10-09-2012, 08:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Coolant leak
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:51 PM
  5. Coolant spray/leak. Quick fix just 1 question
    By VejGTP in forum General Tech Discussion
    Last Post: 12-26-2009, 11:10 PM
