Ok i am having a hard time deciding if i should keep the stock throttlebody and port it as much as I (or Brian) can (mainly removing the hump)or should i go with 78mm polished TB from zzp and port match the inlet on the s/c? I am afraid that i may max out the stock maf so i will aslo prob be getting the lq4 maf either way...so with the mod list below do you think the 78mm tb would help me any performance wise?? or will the stock ported tb suffice??
ALL FROM ZZP
autolite 104's
modified 1.9 roller rockers
comp cms 105 springs and retainers
zzp 3.2 mps
new belt for 3.2 pulley
fullsize intercooler
supercharger coupler
pacesetter coated headers
prj fuel rails
ported blower and lim
The plan is to maximize the cars potenial using the stock cam and stock heads(weather they will be ported or not)
