Thread: Need some help folks, car starts, runs, then dies
Page 5 of 5 FirstFirst ... 345
Results 81 to 87 of 87
  1. #81 Re: Need some help folks, car starts, runs, then dies
    Barksdale AFB, LA
    Unplugging the MAF is the best way to check that. Forces the PCM to rely on the MAP sensor and TPS sensor for fueling, eliminating the MAF from the system.
    2009 Subaru Impreza WRX STI
  2. #82 Re: Need some help folks, car starts, runs, then dies
    Bastard Reptile's Avatar
    Kansas City, MO
    So I was right for once? yay!
  3. #83 Re: Need some help folks, car starts, runs, then dies
    SE Level Member Doin12volt's Avatar
    Nov 2008
    navarre
    So am I to assume you could actually rely on just those 2 sensors to get you to the house should the MAF fail again? I did seem to run just fine without it, but I replaced it anyways just out of principle..
  4. #84 Re: Need some help folks, car starts, runs, then dies
    Oklahoma
    Quote Originally Posted by Reptile View Post
    It was bound to happen soon or latter. Odds say you guess enough, eventually one of them will be right.
  5. #85 Re: Need some help folks, car starts, runs, then dies
    Nov 2008
    navarre
    also, why wouldnt a bad MAF trigger an SES light?? Seems kinda funny - when i REPLACED the sensor, I got an SES for the MAF! I have cleared the code and all is still well.
  6. #86 Re: Need some help folks, car starts, runs, then dies
    seattle
    i basically have the same problem, with essentially the same motor, just 30 years older. i have a 1976 buick with essentially the same 3.8 and it starts and then less then 2 minutes later it dies, and wont re start till much later. could it be the same problem??
  7. #87 Re: Need some help folks, car starts, runs, then dies
    I live here. UR LOSN's Avatar
    Rockford, IL
    vapor locked? I dont not know for sure, but I do not think that a 76 motor would have a CKP........
