Thread: Need help with kr
Results 1 to 10 of 10
  1. #1 Need help with kr
    Missouri
    I have a 98 gtp and the mods I have currently installed are a 180 drilled t-stat, fwi, ssac headers, 3.5 pulley, dhp tune, autolite 104's, flowmaster mufflers and at first I was having up to *16 kr untill I installed the headers. Then it went down to *7 kr and I noticed it got alot of kr when I had and ported supercharger and ported lim done. So I was wondering why that ported supercharger and lim caused all that kr and what I should do.......thanks
  2. #2 Re: Need help with kr
    Probably have a vacuum leak. That and I bet your motor mounts are shot and your front sway bar isn't flipped upside down...and that DP is making contact with the sway bar due to your bad mounts and thats causing false KR
  3. #3 Re: Need help with kr
    Donating Users kfish's Avatar
    Ohio
    dont need to flip the sway bar with ssacs UNLESS you have the GMPP sway bar.
  4. #4 Re: Need help with kr
    Missouri
    With false knock does it make it run like crap? Cause it makes my car run like crap in WOT
  5. #5 Re: Need help with kr
    Quote Originally Posted by 40mphGT View Post
    Sure your not misfiring? And why would you go WOT if something is wrong with your car anyways? It isn't helping it. Any SES lights?
  6. #6 Re: Need help with kr
    Jul 2008
    sumter,south carolina
    false knock will cut timing.
    02 GTP with mods 05 GP for DD
  7. #7 Re: Need help with kr
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    sounds like a vacuum leak to me especially if you just had the blower off and apart
  8. #8 Re: Need help with kr
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    just take a look at your car go over it look for leaks also if u have acess to a scan guage give itr a scan also is there a ses light
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  9. #9 Re: Need help with kr
    Missouri
    I have a friend who uses dhp tuner and he did not say or mention any kind of ses light. However he said I was running lean so he adjusted my maf tables and it helped alittle. So now I have about 6 to 7 kr with only 9 lbs of boost when I have a 3.5 pully
  10. #10 Re: Need help with kr
    6-7* of KR is BAD.
    I'd put the stock pulley back on that thing...or get rid of the false knock that is happening somewhere...headers and a 3.5" in theory is just fine...but something on your car is off.
