Thread: Stock Torque motor Mount Does not match new one? Different design
Results 1 to 5 of 5
  1. #1 Stock Torque motor Mount Does not match new one? Different design
    SE Level Member CheeWee's Avatar
    Feb 2009
    Bay Area,CA
    I went to purchase the Motor/Trans Torque mount and it has this design...
    PartsTrain.com - Hard to Find Auto Parts and Truck Parts -
    The one i currently have does not have the Hook it is a C design. have any of you guys had this problem before?
    Thanks
    98 Camaro Z28
    02 Blue GTP
    K&N FIPKIT, 3.4 Pulley, ZZP PCM, MSD 8.5mm, UbentD, and other small Upgrades
  2. #2 Re: Stock Torque motor Mount Does not match new one? Different design
    Looks like it is missing the bottom half...I'd just return it and go to a junkyard and then buy poly inserts. Done.
  3. #3 Re: Stock Torque motor Mount Does not match new one? Different design
    Feb 2009
    Bay Area,CA
    Yeah and it all the other parts stores Have the same design too. Witch it will fit but I am not sure how it will hold up...
    Might just have to go to junk yard...
    98 Camaro Z28
    02 Blue GTP
  4. #4 Re: Stock Torque motor Mount Does not match new one? Different design
    Junkyard or Morad
  5. #5 Re: Stock Torque motor Mount Does not match new one? Different design
    Jan 2009
    Tallahassee, FL
    You can use them, they will work fine. There are already holes in the radiator support so you can put the bolts in on the front part of the mount. I went through the same thing, all I can think of is that they are a newer design or used on a different w-body. Had mine for a while with rotated mounts and they are holding up fine.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  2. upper motor mount help please
    By Red_GTP in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2008, 01:28 PM
  3. GreenNirvana's Motor Mount
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-03-2008, 08:13 PM
  4. Anyone Want To Buy A Motor Mount? What About an Axle? Lol
    Last Post: 06-29-2008, 11:01 AM
  5. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
