Thread: Fuel pressure 04+
Results 1 to 5 of 5
  1. #1 Fuel pressure 04+
    Portland Oregon
    Anyone know what initial key-on fuel pressure should be on the 04+ returnless system? Also, if anyone can enlighten me as to where if at all there is a fuel pressure regulator in the system? There is a feed and return on the fuel filter. I've been fighting a cold start issue for a while now and I believe it to be fuel related. It only occurs after the car sits overnight. It's as if fuel pressure bleeds off overnight and will not re-pressurize quickly enough at key-on. I try cycling the key several times before first start and it helps sometimes. Thanks
  2. #2 Re: Fuel pressure 04+
    GT Level Member supercharged06's Avatar
    capecod
    I'm not sure or the pressure rating but you might be loosing pressure possibly because of the o-rings on injectors were it meets the rail.
  3. #3 Re: Fuel pressure 04+
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    My cold start pressure was around 64-65 psi, now with a rewire it sees 68-70 at start up. This is on a N/A pump.
    Regulator is in the tank from what I read.
    Retired
    Turbo'd
  4. #4 Re: Fuel pressure 04+
    Portland Oregon
    Quote Originally Posted by VictorSmalls View Post
    Yeah, I'm not seeing that kind of pressure. Key on once I get like 12 pounds. Key on twice it's in the 40's-50's. Key on a third time and it's in the 60's. That's before I did the re-wire, haven't checked it after that but still no change in how the car starts cold. I'm gonna pull the pump and find out if the FPR is replaceable next time it's sunny and I'm low on gas.
  5. #5 Re: Fuel pressure 04+
    Dec 2008
    Tyrone, PA
    Sounds like your on the way. I need to get back there and run a return line and put a bigger pump. On the list for someday.
    Retired
    Turbo'd
  1. Fuel Pressure Gauge
    By SDGTP99 in forum General Tech Discussion
    Last Post: 10-09-2009, 07:31 PM
  2. WOT fuel pressure
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2009, 12:38 AM
  3. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  4. Fuel pressure gauges
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-28-2008, 08:03 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
