I am new to this forum and also am new to the Grand Prix world. I just bought a 2004 Grand Prix GTP that needs a little work. It starts, runs and drives just fine but has a NASTY noise that I originally thought was from the top end. I bought it cheap from a friend, he thought that it may be the supercharger. I looked and listened a little closer with another friend. He thought that it was an internal issue. We took the belts off and started it up for a quick second and still had the noise. I figured that this ruled out any of the front engine components including maybe the supercharger? The noise gets louder and quieter at idle and almost sounds like a flapping noise along with a knock of sorts. I have done my share of repair work on cars but definitely I am no pro.
My questions are:
#1 What are the potential issues I am up against?
#2 Is it possible for the supercharger to be an issue, even if the noise was there after removing the belt?
#3 Are there any other fairly simple checks I should try?
#4 What could cause a noise this bad and the car run and drive ok?
Thanks for your help!
