Thread: Running rich at idle, causing idle issues.
Results 21 to 27 of 27
Threaded View
  1. #1 Running rich at idle, causing idle issues.
    It seems as if it either misses or backfires massive spurt of KR (2-5*) then back to normal and does it again.
    This is after I get between 3-5 lbs into it.
    For those who dont know the car, its a top swap with headers.
    The car doesnt seem to do this when pulling from first gear but then does it when pulling from second gear.
    For the moment, I'm running 14* of timing till this is sorted out.
    At first the car recorded actual misfires, regapped the plugs to 0.050 and then the misfires were gone but not the KR nor the studdering.
    Going to try wires (warranty) next, then ICM (possibly free) then coils (wrecker).
    Edit: this part makes me think its mechanical: It shows KR when in neutral coasting and revving it. Is that normal?
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. low boost
    By andrewdg1983 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 01:05 AM
  3. Boost
    By supercharged06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2010, 08:51 AM
  4. Boost
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 01:14 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
