Thread: Another open cone vs sealed box debate
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 72
  1. #1 Another open cone vs sealed box debate
    Banned
    Mansfield, Ohio
    I've posted this a few other places on this site but I want to hear all opinions. I've caught alot of flack from other sites about the intake I just put on my 98 gtp. Here is my setup, sorry for the bad quality pic.
    Cost me $66 out the door with a $10 off coupon from advance. It's 4 inch tubing with a 45 degree bend, I tried the 22.5 degree bend but the filter was to big and was hitting I believe the cruise control. I bought one 3.5 to 4in coupler, bought a 7/8's holesaw bit for IAT, came with the grommet. K&N filter 4x9 inch very pleased. I actually saw on the butt dyno you can def feel the difference. Supercharger screams like a baby. I also had a old 45 degree elbow and since my car is a 98gtp I already had the triangle duct where the guys use the roof flashing. I attatched the 45 degree bend on the inside of the fenderwell to duct cold air right to the tip of the filter.
    Now here's what another member on another site said about my intake. I don't totally agree with what was said at all, do you?"
    DarkRelic » Mon May 17, 2010 10:49 am
    "I hate to break it to you... although you made a free-er flowing intake, you actually failed by not making a box. It's been showed time and time again that Hot-Air Intakes are worse than the stock intake/airbox.
    The radiator blows the hot engine air right into your air intake.... so instead of taking in air that is near ambient, you end up sucking in air that's usually 50-80 degrees above ambient, so when your supercharger (assuming a stock pulley) increases the air it's forcing into your intake manifold 150-200 degrees over ambient and then you add the extra ~50-80 degrees you are sucking in from the radiator you are doing more harm than good.
    Yeah, stupid ricers who drive naturally aspirated cars can get away with hot air intakes. That's only because they don't have anything amplifying the temperature of the air the engine is taking in to begin with. you have a good start, now make yourself a box.
    Oh and BTW, if you don't want your PCM to be bouncing around in your engine bay, get a chevy S-10 PCM tray."
    Here's my response to the above post I have in quotations,
    In no way shape or form was my stock air box/drop in paper filter out performing what I've got now, absolutely no way. Maybe at bringing in cooler temps but not flow, more air = more power. I'm going to brunswick tomorrow with a friends dad to dyno his supercharged prelude. You want me to take my stock air box dyno it, then put my setup on and dyno it? My filter is not even remotely in front of my radiator. The only time my setup would be sucking in those kind of temps is at a light or not moving. You ever wonder why when going over 35mph there's no need for fans to cool an engine? Same relevance here, especially with that stock junk air box being eliminated. If I relocate the coolant bottle it opens up even more air, not to mention from the reverse 45 degree elbow ducted to run air right to the filter on the inside of the fender.
    I'm not debating that a box wouldn't out perform what I've got right now. Everyone knows cooler, dense air will always make more power. I'd totally agree with you if a car was NA but with a blower car it's different. Plus the stock air box eliminates the ability for air to flow thru the engine bay anyways, now it's wide open. The PCM isn't moving one centimeter the filter holds it down perfectly the way it is. I would like to have the PCM tray but in order for the PCM to lay flat I first need to buy a 99+ coolant bottle.
    If I was good at fabricating I'd build a box but I'm not and I'm not spending $200-$300 on a box it is what it is.
    Open cone 4x9 K&N > stock paper drop in
    4inch pipe with 1 45 degree bend > 98 stock gtp airbox with 2 90 degree bends with corrugated tubing and 2 inch hole for air to flow thru
    Flow > ambient temps especially on a modded car which I'm working on
    $70 > $200-$350+ prices for a box
    Next is headers, 1.95 roller rockers, cooler plugs, 180 thermo, aeroforce scangauge, 3.4 pulley, custom tune , when that's all done we will see where I'm at with knock retard and probably call it quites and focus my attention on suspension and brakes.
    I'm welcome to any opinions good or bad. Thank you!
  2. #2 Re: Another open cone vs sealed box debate
    Charles City, IA
    If you can get on the dyno for free defiantly do the stock air box then your intake then open tb. Your intake is fine I would have went with a dry flow filter tho. Good choice on a big filter. Here is what I did.
    SMGPFC Two Nipple General
  3. #3 Re: Another open cone vs sealed box debate
    im anticipating this thread to try and prove some points that i have been pushing for quite some time. keep us updated.
  4. #4 Re: Another open cone vs sealed box debate
    Charles City, IA
    Also pull out your headlight so the fan at the dyno is pushing air in there.
  5. #5 Re: Another open cone vs sealed box debate
    Apr 2009
    stockton ca
    im open cone on the tb so im intrested im not willing to pay my dyno guy 200 bucks to prove this though lol
  6. #6 Re: Another open cone vs sealed box debate
    Banned
    Mansfield, Ohio
    Is that a flowable filter cover? I've got a dry flow on my type sh made by AEM. I wanted the 9 inch filter though and all the advances around here only had the aem dryflow in way smaller sizes. I could've ordered it but I opted for the now option. Plus the filter only cost me about $42 bucks.
    I don't know if they'll have time to dyno my gtp tomorrow or not. My friend is in Iraq that owns the supercharged prelude and I've been working on getting the kinks out with his jackson racing setup with his dad for sometime now. He runs Hondata so it's a fully tuneable ecu, it was tuned in El Paso, TX and the car is now in Ohio with a definite elevation change.
    If they say ya we will strap your gtp down and do a couple pulls for fun I'll be all over that. I've only done the intake so far so it's not going to be anything impressive but it would be nice to have somewhat of a baseline to go off of. I would put money on my new intake setup out perfoming the stock box by a landslide but some don't think so.
  7. #7 Re: Another open cone vs sealed box debate
    Charles City, IA
    Yes it is an amsoil pre filter. Here are the sizes they cover. PM if interested.
    https://www.amsoil.com/storefront/eapf.aspx
  8. #8 Re: Another open cone vs sealed box debate
    Banned
    Mansfield, Ohio
    The only bad thing is I thru my drop in filter in the trash, I'm still willing to bet that with the stock air box open with no filter on the dyno still wouldn't out perform what I've got now!
    The guy that keeps giving me shi* really urks my nerves. He never rode in my car with a stock air box right? I can tell you when your wife says damn it pulls way harder it probably pulls way harder!
    Anyways the dyno app is at 6pm tomorrow night we will go from there. I'd imagine they will have a couple hrs in the preludes retune so I don't know what kind of time we will be looking at. Plus I'm not paying $200 either to prove what is better than what. I know what is better, a stock air box isn't better than what I'm running now.
  9. #9 Re: Another open cone vs sealed box debate
    i completely agree. i wish there were a dyno disposable locally to me for a cheap price. i would pick up a grand prix and dyno everything for fun and see what the gains were after bolting on and after a tune for each part.
  10. #10 Re: Another open cone vs sealed box debate
    New Jersey
    I would assume theres a lot more to it then just "how cold is the air". a significantly better flowing intake with slightly warmer air probably will produce more power under most conditions. Personally i'd do what I could to try and get fresh air to it.
    What I am curious about (being my 3800 isnt supercharged). These cars are MUCH quieter then the old school blowers where the thing was louder then the exhaust.
    Does having an open intake like this make the super charger significantly louder?
  11. #11 Re: Another open cone vs sealed box debate
    Charles City, IA
    Quote Originally Posted by MrTube View Post
    What I am curious about (being I don't have a super charger) is. These cars are MUCH quieter then the old school blowers where the thing was louder then the exhaust.
    Yes open cone makes the blower a lot lounder. Most of what you hear from the big blowers is the huge cogged belt whining.
  12. #12 Re: Another open cone vs sealed box debate
    the reason why i loved having an open cone: the blower whine. even on a 3.4 pulley it's loud enough to get peoples attention on the highway.
  13. #13 Re: Another open cone vs sealed box debate
    New Jersey
    You know what I don't quite get. From what I understand on a 3800 the supercharger bolts down onto the intake and is essentially part of the intake.
    How do people install intercoolers on this? If the supercharger it self is literally part of the intake.
    Or is there a single large output from the supercharger to the intake which you can re-route?
  14. #14 Re: Another open cone vs sealed box debate
    Charles City, IA
    It is a water to air inter cooler under the charger, pretty much a heater core under the charger. With another radiator in the front of the car to cool of the water once the air heats it up.
  15. #15 Re: Another open cone vs sealed box debate
    you put a set of plates between the intercooler and the lower intake manifold. the plates include a heater core that you run coolant through.
    there are australian guys that have run air to air setups, but the system is fairly complex.
  16. #16
    Banned
    Mansfield, Ohio
    Well I might be in luck for this test, hoping the guy that does the tuning is in a good mood. The engine that's in the prelude is one that I built from the ground up. The guy doing the tuning knows of me and it will be the first time meeting him in person. It all depends on how long the prelude is on the dyno. If they will do 2 pulls for $50 or less I'll do it. If it's free even better, although it will be after hrs so the tuner will probably be ready to go home
    I'm pretty sure the lude will put down some impressive numbers for what it is. It put down 230hp to the wheels and 201ft lbs in texas running very badly. All the kinks are out now, so if he puts down more that will just drive me to get the ball rolling on my GTP. I'm new to this 3800 and having a supercharged car, I'm still learning but I'm heading in the right direction.
    Even between large buildings at wot I could barely hear the supercharger over the stock exhaust with stock air box. After putting my setup on I was like wat, are you serious why did I wait so long to do this! I'm only on a 3.8 pulley and it's loud.
  17. #17 Re: Another open cone vs sealed box debate
    GTX Level Member colindunn's Avatar
    Aurora, IL
    the stock air box is technically "cold air" but its very restrictive. now without a box you have the highest amount of flow, but very hot air. get a box that isnt completly restrictive. or make one to prevent most of the hot air. You have to find a sweet spot between cold/hot air, and flow.
  18. #18 Re: Another open cone vs sealed box debate
    Banned
    Mansfield, Ohio
    Quote Originally Posted by colindunn View Post
    Does it really matter after headers, rockers, intercoolers?
  19. #19 Re: Another open cone vs sealed box debate
    Florida
    I agree, if you're restricting air flow - bad
    and if it's hot air - bad
    I personally like a box, since it helps keep some heat out, which there's quite a lot of heat underhood now since I installed my headers.
    My only thought on an open cone would to be to try to get it closer to the fender/headlight, and try to get it closer to that cold air/away from the hot air.
  20. #20 Re: Another open cone vs sealed box debate
    Quote Originally Posted by cleangtp View Post
    EXACTLY.
    if you ever go with an intercooler and DON'T go open cone then you're missing out on some flow. cool air in the intake charge DOES matter, but to what degree do the diminishing gains from restrictions (read: bends) help you out?
  1. open cone
    By CompCam21 in forum General Tech Discussion
    Last Post: 06-05-2010, 09:39 PM
  2. open cone filter
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 04-20-2010, 10:47 PM
  3. spectre open cone IAT placement.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-16-2010, 07:47 PM
  4. open cone filters
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-16-2009, 07:30 PM
  5. Open Cone Performance.
    By PontiacGTPSE in forum Off Topic Discussion
    Last Post: 10-21-2009, 11:03 AM
