Anyone know what initial key-on fuel pressure should be on the 04+ returnless system? Also, if anyone can enlighten me as to where if at all there is a fuel pressure regulator in the system? There is a feed and return on the fuel filter. I've been fighting a cold start issue for a while now and I believe it to be fuel related. It only occurs after the car sits overnight. It's as if fuel pressure bleeds off overnight and will not re-pressurize quickly enough at key-on. I try cycling the key several times before first start and it helps sometimes. Thanks
