Thread: MAP Sensor Operation/Issue
Results 1 to 2 of 2
04DetroitLS MAP Sensor Operation/Issue 05-22-2010, 09:12 PM
torq455 Re: MAP Sensor Operation/Issue 05-23-2010, 07:44 PM
  1. #1 MAP Sensor Operation/Issue
    SE Level Member 04DetroitLS's Avatar
    Detroit, MI/Lakeshore, ON
    Here's our symptoms, first start up the car, runs fine, after 5-10 minutes it will start to behave very badly, become EXTREMELY rich, back fire, all that crap, and doesn't resume being good again until it's shut down for a minute and restarted.
    We discovered the vac line to the MAP sensor had completely failed, but not the one to the FPR.
    Would the lack of a vac source to the MAP cause these problems?
    Thanks.
  2. #2 Re: MAP Sensor Operation/Issue
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    yes. low vac to the MAP means the PCM thinks the car is at WOT, so it adds fuel. any codes?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. o2 Sensor issue
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 11:22 PM
  2. info about headlight switch operation...
    By gtp40th in forum General Tech Discussion
    Last Post: 02-14-2010, 01:39 PM
  3. mass airflow sensor issue,
    By will54768 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2010, 01:19 AM
  4. Open/Closed Loop Operation
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2009, 08:52 PM
  5. PCV Operation?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-21-2008, 10:27 PM
