Thread: Who is running ARP head studs???
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Who is running ARP head studs???
    Oklahoma
    Quote Originally Posted by archemedes View Post
    don't studs just clamp better really? I think that's what I have always been told
    Thats exactly what I have read many times. Bolts are twisting and tightening at the same time so you have two forces working on it, whereas the studs just have the tightening.
  2. #22 Re: Who is running ARP head studs???
    Barksdale AFB, LA
    At what point would these be required? I mean, what issues do people have that these remedy? I can't see the heads blowing off our engines or anything... Is it simply for better sealing with better gaskets?
    2009 Subaru Impreza WRX STI
  3. #23 Re: Who is running ARP head studs???
    Oklahoma
    I dont know that they 'remedy' and existing issue aside from the fact they are just added insurance that you wont blow the gasket. In other words, they just work better than stock bolts. They are stronger (more tensile strength) than stock, clamp better than stock, etc.
    That said, I watched a thing on TV not too terribly long ago, it may have been 'How Its Made' where they went and showed how ARP bolts were made and all that process. And they put some work into those suckers I tell ya.
  4. #24 Re: Who is running ARP head studs???
    Apr 2008
    sacramento ca
    i got the 12pt arp head stud kit 0 miles hehehe
    basically arp head studs provide a better seal between the headgasket and head to block,
    a regular bolt basically pulls on the head, where as a stud pushes on the head giving it more clamping force meaning better seal
    just order the set through summit racing for 97 shipped
  5. #25 Re: Who is running ARP head studs???
    Barksdale AFB, LA
    Quote Originally Posted by porkyzilla View Post
    I completed three semesters of college physics and that makes no sense to me how its different. A force is a force. A push is a pull only looking from a different direction.
    I can understand if you're able to tighten them more than with the regular bolts (stronger)... otherwise the same downward force (measured in pounds, newtons, whatever you like) is being exerted if you followed the same tightening specs.
  6. #26 Re: Who is running ARP head studs???
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    ^^^ this had me wondering as well, but from a laymans POV.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  7. #27 Re: Who is running ARP head studs???
    Bastard Reptile's Avatar
    Kansas City, MO
    I'm not really, and totally sold on Head studs if you aren't building/tearing down an engine constantly. They're good in the way you aren't putting wear and tear on the block, but I really can't see how they seat and clamp better.
    TTY bolts actually conform to the imperfections of the threads, and the machining of the head, etc....just from the way I look at it, if you end up having to pull the rear head, which is a pain to begin with, you'll still have to pull the studs out or pull the engine.
    Not bagging the studs, but I could spend my cash on another part and have just as much success.
  8. #28 Re: Who is running ARP head studs???
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I was always told that studs allow for a more accurate torque. Now wether that is true or not I don't know.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  9. #29 Re: Who is running ARP head studs???
    easier to line up gaskets as well as the heads. niiice.
  10. #30 Re: Who is running ARP head studs???
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Quote Originally Posted by Trannyman95 View Post
    That is definately what I am looking for, thanks! I wasnt sure the limit that guys were pushing the stock/felpros and thought it was upper teens in boost but it makes me feel better seeing the 20 number as someone else is doing it.
    That's on an L26 as well, so there's some serious pressure invovled.
    Lumpy Gen 3
  11. #31 Re: Who is running ARP head studs???
    SE Level Member TheRealKoop's Avatar
    Lima, Oh
    High power applications need more clamping force, which is granted with arp studs. TTY bolts will just stretch and never really torque more then they are designed to. We dont want to be lifting heads now do we?
    97' GTP- HAI| 160| N*| Ported Blower| 2.55"|
    S2 ZZp IC| LIM| Heads| 50#| XP| Pacesetters| Flow40's
    AL 103| S2 Volt Booster| Alt rewire| FP rewire.
    Built Tranny| Poly Mounts| 3.69's| 3000 stall.
    Walbro 255|AEM WB| Powertuner.
  12. #32 Re: Who is running ARP head studs???
    Toronto, ON, Canada
    Just an Update, buddies car just made 541whp and 500wtq on Fel pro's and ARP's. 20psi and 20* of timing.
    Lumpy Gen 3
  13. #33 Re: Who is running ARP head studs???
    New Salem, ND
    Wow that sounds impressive, what are his mods?
  14. #34 Re: Who is running ARP head studs???
    Toronto, ON, Canada
    Quote Originally Posted by Andrew_99GTP View Post
    http://www.grandprixforums.net/f14/d...html#post46119
    Lumpy Gen 3
  15. #35 Re: Who is running ARP head studs???
    SE Level Member Arkanzan Wheeler's Avatar
    Apr 2008
    I have the ARP studs with a few extras, making it hold 27 psi according to ZZP. Look below the spark plug holes and you can see the extras.
    2000 Daytona 500 Edition
  16. #36 Re: Who is running ARP head studs???
    Barksdale AFB, LA
    So just how hard is it to get these to seal? I hear about needing a lot of teflon tape. Just curious if it's something I may want to do.
  17. #37 Re: Who is running ARP head studs???
    Hoffman/Schaumburg, IL
    The Teflon tape is needed because the bolt holes for the head bolts lead into the coolant passages(water jacket), so when you put the stud in if you don't tape the portion going into the block, there is a good chance(not a guarantee) that you will seep coolant out from the head studs
  1. pacesetters are way better than SLP's...when running a 4T80-E
    By turbocharged406sbc in forum Off Topic Discussion
    Last Post: 04-01-2008, 02:20 AM
  2. Studs
    By wrfdff4 in forum Tires & Wheels
    Last Post: 03-31-2008, 11:16 PM
  3. Thinking about running Drag Radials...
    By Iron Indian in forum Tires & Wheels
    Last Post: 03-27-2008, 12:13 AM
  4. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
  5. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
