Thread: Another open cone vs sealed box debate
Results 1 to 20 of 72
  1. #1 Re: Another open cone vs sealed box debate
    SE Level Member prixgt01's Avatar
    Schaumburg,il
    Quote Originally Posted by colindunn View Post
    the stock air box is technically "cold air" but its very restrictive. now without a box you have the highest amount of flow, but very hot air. get a box that isnt completly restrictive. or make one to prevent most of the hot air. You have to find a sweet spot between cold/hot air, and flow.
    I agree, if you're restricting air flow - bad
    and if it's hot air - bad
    I personally like a box, since it helps keep some heat out, which there's quite a lot of heat underhood now since I installed my headers.
    My only thought on an open cone would to be to try to get it closer to the fender/headlight, and try to get it closer to that cold air/away from the hot air.
    So quick question on this one, new and trying to learn as much as possible, is it possible to keep the stock box and,and some how make it as as a frre flowing box, like the one in your sig with the plexi on top?
  2. #2 Re: Another open cone vs sealed box debate
    GTX Level Member colindunn's Avatar
    Aurora, IL
    yeah you can cut it if you want. except probably cant use the stock air filter if thats what you want. but people have modded the stock airbox to go with a conical filter.
  3. #3 Re: Another open cone vs sealed box debate
    Banned
    Mansfield, Ohio
    Quote Originally Posted by prixgt01 View Post
    My stock air box from my 1998gtp has 2 90 degree bends, and corrugated tubing, why on earth would you want to use this setup?
  1. open cone
    By CompCam21 in forum General Tech Discussion
    Last Post: 06-05-2010, 09:39 PM
  2. open cone filter
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 04-20-2010, 10:47 PM
  3. spectre open cone IAT placement.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-16-2010, 07:47 PM
  4. open cone filters
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-16-2009, 07:30 PM
  5. Open Cone Performance.
    By PontiacGTPSE in forum Off Topic Discussion
    Last Post: 10-21-2009, 11:03 AM
