That is once I get the top swap done.
been in a top swapped car with an XP, headers and a 3.4... it put you back and held you there.
You need a custom adapter plate. but if i were you i'd make that adapter the I/C as well.
Thats if you have a large budget and want to start pushing around 15 lbs of boost via supercharger, in other words, you need a cam, headers, I/C and possibly headwork to take full advantage of it all.
That sounds like how my Cobra was. Of course after 4K you watched the boost start dropping off from 13 to about 8 or 9 at 6K. Still fast as all get out though.
so imagine it with a bigger blower on it.
yeah, you need a custom plate to go between the LIM and the blower.
You need the snout and rotors from a M112 and you reuse your m90 case.
Its better to sit down and plan it all out BEFORE buying anything really. :D
I'm meaning the hybrid; using the M90 case with M112 innards. I have the M90 (or will on Friday rather). I know where I can get the M112 parts. I need those plates.
find a shop that has a CNC lathe and they should be able to make them for you.
It'll be CHEAP too.
:p
some info on the subject
http://www.grandprixforums.net/f49/g...kits-1108.html
nah, the car has been on the same set up for a while now. aint really had the time to fool with it.
if you could find someone to make the plates it seems like a pretty easy swap.
