Thread: Misfiring after Gen 5 install!
Results 1 to 20 of 26
  1. #1 Misfiring after Gen 5 install!
    Lima, OH
    Well let me start from the beginning when I first started the car after getting the car back on the road after a year or so of sitting in drive way from being wrecked. I bought a motor and installed it. Like right away it was getting some where around 2-8 misfires so i bought some new plugs and gapped them at .055 but it still did it! So even when I dropped pulley sizes down to a 3.4 on my setup no changes in it! So after a while I then bought some PRJ plug wires and some new plugs again, installed them and re-gapped them agian, no changes yet again! Then changed the ignition coils no changes with that. Then bought a brand new ICM which blew one of my big 40amp starting fuses after i put the old one back and was taking back the new ICM thinking that the new one was bad! So now i installed a my Gen 5 on the car and now some how Im getting 170 misfires with no codes for it at all! I have changed just about every sensor on the car but the cam sensor! Im running out of ideas on whats causing this crap so if any body can help it would help me out alot!
  2. #2 Re: Misfiring after Gen 5 install!
    Nov 2010
    Atlanta Ga
    Do you know which cylinders are missfiring? Check spark. Injector balance. Or start with a compression check
  3. #3 Re: Misfiring after Gen 5 install!
    Sat for a year? My bet is bad gas. Honestly...I had to let mine run to blow it all out and I tossed a few bottles of octane booster in and it really smoothed things out.
    My question to you...why are you continually throwing mods at it before fixing an issue...especially running a 3.4" on a GenV? I hope for your sake you've got a cam/intercooler/headers to go with that setup. Funny, when you yank your plugs out...are the tips bent at all? If so...then you've got internal damage.
  4. #4 Re: Misfiring after Gen 5 install!
    You should really change the title.
    Misfiiring before 3.4, before new plugs, before Gen V. Please accept my apology in advance, but are you a moron? are you thinking when you have a misfire and think dropping pulley size, or adding other mods are going to magically solve it?
    You don't mention new plug wires, ???? If you haven't.. you better
    You don't mention fresh fuel ??? if you haven't.. you better
    You don't mention if the #4 or #6 wires are touching the O2 sensor wiring.. please ensure they aren't.
    You don't mention if the TB was cleaned
    You don't mention if you checked for vacuum leaks
    You definately don't mention the most important thing.. which cylinder is misfiring.
  5. #5 Re: Misfiring after Gen 5 install!
    Or, if there are any SES lights for that matter.
  6. #6 Re: Misfiring after Gen 5 install!
    Bastard Reptile's Avatar
    Kansas City, MO
    Well, he did say he put on PRJ wires, and it's not throwing a code. However, nothing else about how far he drove it etc.
    Lots of aftermarket PCM's have the misfire SES code set to pretty much not show a light, so that could be out the window.
    More info is needed for sure. Crappy fuel will not burn well, so have you run a tank of clean fuel through it? Which cylinder is it? If it's one specific one then you can trace down the problem there.
    If the P0300 code has been completely disabled, it might not even show up on the individual cylinder, and I've seen this many times.
  7. #7 Re: Misfiring after Gen 5 install!
    Lima, OH
    Sorry i did drive it for a while! It does have fresh gas in it since then! I forgot to mention that i did replace all of the vacuum liines! ITS NOT TELLING ME WHICH CYLINDER OR NO CODES ITS JUST SHOWING ME THAT THE CAR IS MISFIRING!!!!! I was running a 3.4 with my Gen3 but Im running a 3.8 with the Gen5! I have been dealing with these misfires and tring to fix them for the past 2 years since i have owned this car and so far not thing else has fixed it!
    Last edited by gtptim; 11-16-2010 at 03:10 PM. Reason: i have forgot some things to add to this post!
    1/8mile: 9.354sec@77.026mph the best 60ft: 2.211sec
    1/4mile: 14.2889sec@93.16mph the best 60ft: 1.9668sec
  8. #8 Re: Misfiring after Gen 5 install!
    Holy crap...a 14.2 @ 93? That thing is knocking like a b1tch.
  9. #9 Re: Misfiring after Gen 5 install!
    Lima, OH
    why would it be knocking?
  10. #10 Re: Misfiring after Gen 5 install!
    Because your trap speed is lower than sin. And knock pulls timing in the PCM...and less timing is less power...less power means slow
  11. #11 Re: Misfiring after Gen 5 install!
    Lima, OH
    I would always be scanning when going down the track never did see any KR happening!
  12. #12 Re: Misfiring after Gen 5 install!
    What are you using to scan then?
    btw...your sig...is huge. Jesus H Christ.
  13. #13 Re: Misfiring after Gen 5 install!
    Wanna try different gas station?
    Also, please resize your sig or get rid of it.
    if you need help with that, just ask.
  14. #14 Re: Misfiring after Gen 5 install!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    when is it misfiring? driving, under idle?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  15. #15 Re: Misfiring after Gen 5 install!
    Probably all the time with the pieces of piston missing
  16. #16 Re: Misfiring after Gen 5 install!
    Charles City, IA
    What are you using to scan? If it is showing misses it will show what cylinder. Have you clean the injectors? Fuel filter new? Maf good?
    SMGPFC Two Nipple General
  17. #17 Re: Misfiring after Gen 5 install!
    Lima, OH
    Quote Originally Posted by 01gpgt01 View Post
    its only doing it under idle as far as I know it I havent driven it since!
  18. #18 Re: Misfiring after Gen 5 install!
    Lima, OH
    Its not going to matter to me about resizing my sig considering that Im not going to be here for very long any ways since Im getting responses like the ones quoted below! Looks like I found another forum just like clubgp JUST FULL OF DICKS!!!!
  19. #19 Re: Misfiring after Gen 5 install!
    SE Level Member deangtp's Avatar
    Kansas City, MO
    1) Try seafoam in your gas. My sister has an 04 Impala. She brought it to me, we switched out stuff from my car to hers, new wires, new plugs, ICM, coils. Nothing fixed it. I could see the misfires on my powertuner, but couldn't figure it out. She took it to a shop that said she had low compression on one cylinder. She put seafoam in it and it went away. Maybe a sticking valve. I don't know. It comes and goes though. It started doing it again a couple of months ago. Same remedy. I have no explination
    2) Blue is a dick.
  20. #20 Re: Misfiring after Gen 5 install!
    Quote Originally Posted by deangtp View Post
    2) Blue is a dick.
    3) Dean won't get his car clean.
  1. SS M90 misfiring due to tune?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 10:38 PM
  2. Misfiring
    By Kazmoe in forum General Tech Discussion
    Last Post: 02-20-2010, 07:10 PM
  3. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
  4. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  5. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
