Thread: Rotor coating
Results 1 to 20 of 22
  1. #1 Rotor coating
    Banned - Busted For Scamming
    Feb 2009
    So, i was cleaning off a pair of rotors for spartangl, and these were 65k rotors. They were in good shape, no nicks or anything. I soaked them in a hot soapy water solution for 30 min, came to check on them and this is what i found. No chemicals were used in this process. Also, no tools other then my hands were used in this process. I want to point out that all the guys saying water meth is to blame are probably wrong. Like i was telling everyone before, the factory coating is flawed, they just didnt prep it correctly. Enjoy.
  2. #2 Re: Rotor coating
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Wow! thanks for sharing.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: Rotor coating
    ive always said that water/meth/alky doesnt kill the rotors...
  4. #4 Re: Rotor coating
    GTP Level Member Scimmia's Avatar
    QCA, IA
    How do you figure? Looks to me more like water IS the problem.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Rotor coating
    Nov 2009
    Grand haven
    My wife would be pissed if i was doing that in the sink!! Thanks for the info though. Just wondering what you use to recoat the rotors the Correct way?
  6. #6 Re: Rotor coating
    Feb 2009
    Quote Originally Posted by Scimmia View Post
    People were saying that the methanol was eating the rotors. This is different.
  7. #7 Re: Rotor coating
    Apr 2009
    stockton ca
    wow thats crazy stuff
  8. #8 Re: Rotor coating
    Outer Space
    Soap has chemicals, unless your strictly using animal lard
    02 GTP 13.6 @ 100mph - SOLD
  9. #9 Re: Rotor coating
    Feb 2009
    Quote Originally Posted by Lawngoose View Post
    Well im sorry i didnt mention that, lol. If you want to get technical here thats fine. I was simply stating my results. If you cant trust your rotor coating to hold up to a little dawn, I would not be running it on my motor. Thats what i was trying to get at here.
  10. #10 Re: Rotor coating
    Outer Space
    I agree with you... however my rotors were perfect when I pulled my 02 sc around 120k. I wonder if the rotors were outsourced to a different group by gm... so some are crappy, some aren't. But then again, things like living next to an ocean could also be a factor.
  11. #11 Re: Rotor coating
    Feb 2009
    These were perfect as well. Not a nick on them. I'm saying that no matter what, they weren't prepped right. This proves it. Hands down. I can see a chip here or there, but the ENTIRE coating came off in full pieces. Clearly flawed.
  12. #12 Re: Rotor coating
    Donating Users
    South Deerfield, MA
    I need some dish detergent that works that well on dishes.
    Thanks for sharing the info.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  13. #13 Re: Rotor coating
    Donating Users blowfishRus6's Avatar
    g.a.
    Quote Originally Posted by shawngtp View Post
    question at hand. how do you go about fixing something like this mini??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  14. #14 Re: Rotor coating
    Feb 2009
    I recoat the rotors with a lifetime coating.
  15. #15 Re: Rotor coating
    Wichita, KS
    The rotors are to blame.
    They are cast, machined to tolerance, and then coated with a nice smooth glass like surface still being on the rotors. The coating has nothing to bong to because the surface is not prepped right. You know how you have to break the gloss finish with sand paper before you can paint it? Same thing here, in this case, no prep work was like painting unetched glass.
    Eaton knew it...and GM knew it. They changed their method of production, application, and material used when they created the GenV. They knew they effed up...too late now ya know.
    Some got a good bond, some did not.
    Blowing nitrous through the rotors doesn't even kill the coating or cause damage. I did this through my old GenIII and GenV, no ill effects.
    One local tuned and raced the hell out of his car on a meth. kit, and when we swapped his GenIII for a GenV, his GenIII rotors looks perfect. And he was HARD on his car.
    One person started the rumor, and almost everyone follows it. Kinda like people saying the coating is Teflon on the GenIII's.
    ~F~
  16. #16 Re: Rotor coating
    Largo, Florida, United States
    FYI the Pics of the New Engine will be up soon
  17. #17 Re: Rotor coating
    What does that have to do with Rotor Coating?
  18. #18 Re: Rotor coating
    Charles City, IA
    what does that have to do with rotor coating?
    everyting
    SMGPFC Two Nipple General
  19. #19 Re: Rotor coating
    everyting
    Mu
    st
    BE
  20. #20 Re: Rotor coating
    lol the entire topic had to do with the rotors that are in my car now.
  1. Does meth eat s/c rotor coating?
    By 99prixgt in forum General Tech Discussion
    Last Post: 03-31-2010, 04:54 PM
  2. Anyone have experience with clear coating?
    By pontiacgp759 in forum Tires & Wheels
    Last Post: 08-04-2009, 01:42 PM
  3. powder coating
    By MetalMan in forum Tires & Wheels
    Last Post: 04-09-2009, 06:33 PM
  4. Ceramic coating
    By UR LOSN in forum General Tech Discussion
    Last Post: 02-20-2008, 03:56 PM
  5. coating on tails
    By Toasty in forum Visual/Body Modifications
    Last Post: 01-17-2008, 04:52 PM
