Thread: Tickeng noise when letting out of boost
Results 1 to 7 of 7
supercharged06 Tickeng noise when letting... 04-29-2010, 09:15 PM
blueguy Re: Tickeng noise when... 04-30-2010, 11:49 AM
supercharged06 Re: Tickeng noise when... 05-01-2010, 12:20 AM
putskijr Re: Tickeng noise when... 05-03-2010, 09:14 AM
Juanmiguel Re: Tickeng noise when... 05-03-2010, 12:34 PM
Space Dynamics Re: Tickeng noise when... 05-04-2010, 12:32 AM
supercharged06 Re: Tickeng noise when... 05-04-2010, 06:26 AM
  1. #1 Tickeng noise when letting out of boost
    GT Level Member supercharged06's Avatar
    capecod
    Hey guys gota question. Anyone know what would cause a ticking noise that sounds like its coming out of the S/C...it comes an goes. only happens just out of even alittle boost. Is it a bearing in the S/C it self? Ik its not comeing outa the motor cause a rod would be a constant tick
    if i have no boost it will not happen. low on oil maby? let me know Thanks
    90,000 Miles on motor BTW
  2. #2 Re: Tickeng noise when letting out of boost
    Could be the coupler. They go bad.
    Buy a green one from ZZP thye last forever.
  3. #3 Re: Tickeng noise when letting out of boost
    capecod
    coupler on the S/C? or motor?
  4. #4 Re: Tickeng noise when letting out of boost
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    s/c
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  5. #5 Re: Tickeng noise when letting out of boost
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Have you installed an intake? I hear a ticking sound too when it's just around 0 psi under acceleration, right before the SC kicks in and my coupler is new.
    I only started noticing this sound when I installed an intake.
  6. #6 Re: Tickeng noise when letting out of boost
    SE Level Member Space Dynamics's Avatar
    Beltano Orbital Station
    I had the same problem, ended up having an exhaust leak. (front manifold cracked, stupid me)
  7. #7 Re: Tickeng noise when letting out of boost
    capecod
    no still stock intake...My motor went dead lean for some reason. GM is saying my ECU was surging. I was like..."OK?" My oil pump is driven by the cams, has nothing to do with my ECU. Then they said "You threw timing 16-18 degrees." GM is putting a new motor in it as we speak UNDER WARENTEE!!!!
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. Not letting me post a "For Sale" thread! WTF?
    By 01SmokedGtP in forum Introductions/Noob Questions
    Last Post: 04-29-2010, 10:13 PM
  3. air noise under boost
    By hourang in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:55 PM
  4. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
