Thread: what cam to get
Results 1 to 20 of 25
  1. #1 what cam to get
    Canada
    I have a 2002 grandprix gtp supercharged. So far i have a zzp pcm, K&R cai, slp headers and slp exhaust catback with a slp high flow cat. I want to put in a cam but i need to know all that i will need because i am buying everything and paying someone to do the work. What cam to get + what needs to be replaced with it or upgraded? and whatever else i should have done at the same time its being taken apart so i can get it back on the road. I know afterwards i will have to get the pcm reprogrammed for the cam etc. I am just looking for a list of what i need to get everything done and helps with more power. I have another used transmission I will be getting put in too i have questions about that but i will ask those after Thanks
  2. #2 Re: what cam to get
    Charles City, IA
    What do you want out of the car? dd?
    SMGPFC Two Nipple General
  3. #3 Re: what cam to get
    Apr 2009
    stockton ca
    All depends how mild or wild you want it I have a s1x cam and love my car very dd friendly and has a lot more punch then stock and is stock head friendly
    so is the xp cam
    if you go more wild on the cam youll want head work
  4. #4 Re: what cam to get
    Canada
    I am looking for speed...I have other cars but i still want to drive this one on the highway etc.
  5. #5 Re: what cam to get
    Canada
    what about the thrasher cam
  6. #6 Re: what cam to get
    Charles City, IA
    I would go with intense stage 3 cam and #130 springs.
    INTENSE-Racing.com: INTENSEâ„¢ Supercharged/Blower 3800 Camshafts
  7. #7 Re: what cam to get
    Charles City, IA
    Quote Originally Posted by nextway View Post
    I have the trasher cam. It sounds sexy, but other cams will make more power.
    YouTube - Grand Prix gtp TEP open headers
  8. #8 Re: what cam to get
    Apr 2009
    stockton ca
    the stage 3 cam sounds sweet
  9. #9 Re: what cam to get
    Jersey
    xpz, head-work and 130's
    16' wrx sti- stock
  10. #10 Re: what cam to get
    custom grind...and #150 springs, with stage 4 heads and a double roller with a L26 bottom end and a intercooler with huge injectors and E85.
    11's? yes.
  11. #11 Re: what cam to get
    Charles City, IA
    11's? yes.
    When is yours going to run, so it can blow up with mine lol.
  12. #12 Re: what cam to get
    did you guys seriously just give all those suggestions to a guy who doesnt really know what he wants out of the car? wowzers.
    define 'fast'.
  13. #13 Re: what cam to get
    Canada
    what i am looking for is to change the cam only for now..like what is the best cam and what all i needed with the cam...like springs, push rods etc and what i might want to change so i have no problems as a result of having a new cam
  14. #14 Re: what cam to get
    Headers...pulley and a tune.
    Try those first. Or, read my thread in my signature. That's a start since you don't really know what a cam does for these cars or what is needed to support it.
  15. #15 Re: what cam to get
    Canada
    i already have slp headers, slp catback exhaust with slp high flo cat, K&N cai and a tune from zzp (i want to get a new tune i think the zzp one is causing my tranny problems.)
    if i do the cam at the same time i will get the colder thermostat, new plugs, wires and coil, and new smaller pully etc i also have a used tranny to swap but before that i want to do what i can to it without a total rebuild just to make it last a little longer and maybe add a shift kit...thats a whole other thread tho.
    I think right now i was just looking for the next step and i thought that might be a new cam and whatever else i might need to make sure i dont do any damage to the engine
  16. #16 Re: what cam to get
    you cant just 'run a cam'. it comes with other things that you have to do.
  17. #17 Re: what cam to get
    Canada
    yes thats why i started this thread...to find out the best cam to get and what all i need to upgrade as well...like the valve springs push rods etc.....thats what i am asking for specifics.
  18. #18 Re: what cam to get
    Donating Users blowfishRus6's Avatar
    g.a.
    most cams are gonna require atleast 90 to 105 valve springs.
    get a new stock timing chain and dampner. you can use the stock pushrods.
    i would say s1x, pretty good mid level cam.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  19. #19 Re: what cam to get
    do you want to have to mod your heads or do you want to stay on stock heads?
  20. #20 Re: what cam to get
    Portland Oregon
    Go with the intense s1x, or zzp's xp cam. You will need the following....
    New timing chain and dampener
    front cover gasket
    cam bolt (these are torque to yield)
    crank bolt (these are torque to yield)
    rocker bolts (these are torque to yield)
    valve cover gaskets
    lower intake gaskets
    s/c gasket and o-rings
    fuel injector o-rings
    depending on th shape of you lifters you may want to replace them if you're motor has high miles, if this is the case then just get some ls7 lifters.
    Crow 105 valve springs with ls1 retainers
    viton valve oil seals
    you should be set with that. Obvious fluids and arp assembly lube are additional.
    With those mods you could easily pulley down to a 3.4 or even a 3.25 with a good tune and be in the low 13's or knocking on 12's door with an intercooler later on
cam
