Thread: gtp: sputtering on idle then dies
Results 1 to 6 of 6
  1. #1 gtp: sputtering on idle then dies
    green bay
    all right i have search the net for about two hours and am about to leap in to the fourms. sorry. so i own a 97 gtp no mods. she will start just fine but once the car starts to idle down from the starting process it will begin to sputter. it kind of sounds like its not getting fuel but im really straped for cash so just looking for some ideas. (things i have replaced> fuel pump coil packs, plugs, wires, vacum hoses, maf.) wells theres more but. by the way the only code that is returned to me is p1652 it has been there for ever so props if you figure that one out.
    Thanks in Advanced
    ryan
  2. #2 Re: gtp: sputtering on idle then dies
    Charles City, IA
    What did the old plugs look like when you pulled them out.
    SMGPFC Two Nipple General
  3. #3 Re: gtp: sputtering on idle then dies
    Unplug the maf sensor. It'll be a little tough starting and you may need throttle for a minute or so to keep it running. The test is good though. If it runs better unplugged, it's typically the maf.
  4. #4 Re: gtp: sputtering on idle then dies
    green bay
    all the plugs were fine the last time they were pretty clean. thaks for the maf test ill go check that now. thanks
  5. #5 Re: gtp: sputtering on idle then dies
    green bay
    so the i know its not the maf. i took 4 or 5 times just to keep it running then it would idle at 1700 but i pluged it back in and everything worked just fine. well except the car dieing
  6. #6 Re: gtp: sputtering on idle then dies
    Hobart
    hey, I was searching around and found your post, did you ever resolve the issue? BTW a p1652 is a is a problem with your high speed fan. I am having that issue right now and haven't figured it out yet. I'm going to start a post about it right now so search for that, maybe we'll figure something out.
  1. sputtering problem
    By Risinnfallen in forum General Tech Discussion
    Last Post: 01-07-2011, 06:00 PM
  2. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  3. Help with 2000 GTP -- engine sputtering
    By cartman68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2009, 10:07 AM
  4. help. car sputtering at wot.
    By 1gtp99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 05:15 PM
  5. sputtering in the upper rpms?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-06-2008, 04:36 AM
