Thread: Need PCM wiring diagram or perhaps pin for MAF
Results 1 to 5 of 5
  1. #1 Need PCM wiring diagram or perhaps pin for MAF
    Minot AFB
    Seems like I get no signal on the yellow wire fromt he MAF and my MAF reads 0. I tried a new MAF and same thing. I'm guessing it must be the wire so I wanted to bypass it to test. What pins on the PCM are for the MAF
  2. #2 Re: Need PCM wiring diagram or perhaps pin for MAF
    Charles City, IA
    IGN 1 fuse is probably blown, it is in the under hood fuse block.
    SMGPFC Two Nipple General
  3. #3 Re: Need PCM wiring diagram or perhaps pin for MAF
    Minot AFB
    hey thanks. I wiill check and report back...I also managed to find what pin the MAF is on the PCM...so if the fuse fails I'll go after a direct connection
  4. #4 Re: Need PCM wiring diagram or perhaps pin for MAF
    Minot AFB
    I re-wired the MAF and replaced IGn 1 + UH fuse (15A) which was blown...works like its supposed to. Hope it doesn't blow again as that might suggest an underlying problem...Thank You!
  5. #5 Re: Need PCM wiring diagram or perhaps pin for MAF
    Charles City, IA
    Quote Originally Posted by aimhigh86 View Post
    Mine was blown, I replaced the maf and it has not blown again. I thought it was a maf issue, untill I looked in the repair manual.
  1. Sunroof wiring diagram
    By PCweber in forum General Tech Discussion
    Last Post: 03-30-2010, 11:13 PM
  2. fog light wiring diagram
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2009, 06:58 PM
  3. 02 speaker wiring diagram
    By duffinator775 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2009, 11:29 AM
  4. Monsoon wiring diagram?
    By GiAnT4LYFE in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2009, 03:34 PM
  5. wiring diagram for 05 non monsoon
    By 05grndprix in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2008, 02:56 AM
