Thread: cylinder misfire code on #4
Results 1 to 2 of 2
  1. #1 cylinder misfire code on #4
    virginia beach
    The plugs and wires are not more then 8 mths old, so when i checked them i found a small deposit of oil on the end on the plugs, I cleaned them and put them back ran good for a bit then code again shop said little to no reading on that cylinder. Was thinking that oil was leaking and fouling the plugs any idea what to change or fix i am not ase tech of any sort, but i like to learn. car is a 2000 GTP
  2. #2 Re: cylinder misfire code on #4
    Charles City, IA
    Do a compression test on the cylinder. Might have a junk piston.
    SMGPFC Two Nipple General
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  3. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  4. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
