Thread: air noise under boost
Results 1 to 19 of 19
hourang air noise under boost 01-05-2010, 02:50 PM
kfish Re: air noise under boost 01-05-2010, 03:18 PM
hourang Re: air noise under boost 01-05-2010, 03:19 PM
Bio248 Re: air noise under boost 01-05-2010, 07:52 PM
hourang Re: air noise under boost 01-06-2010, 09:50 AM
badbrad Re: air noise under boost 01-06-2010, 10:36 AM
hourang Re: air noise under boost 01-06-2010, 11:38 AM
badbrad Re: air noise under boost 01-06-2010, 11:58 AM
hourang Re: air noise under boost 01-06-2010, 12:31 PM
badbrad Re: air noise under boost 01-06-2010, 12:00 PM
Bio248 Re: air noise under boost 01-06-2010, 01:32 PM
GTPJAY Re: air noise under boost 02-06-2010, 12:15 PM
Joe m Re: air noise under boost 02-06-2010, 12:56 PM
hourang Re: air noise under boost 02-08-2010, 06:46 PM
DaytonaGTP Re: air noise under boost 04-18-2010, 07:56 PM
hourang Re: air noise under boost 04-19-2010, 03:56 PM
ZR1Vette09 Re: air noise under boost 04-20-2010, 04:51 PM
hourang Re: air noise under boost 04-20-2010, 04:52 PM
ZR1Vette09 Re: air noise under boost 04-20-2010, 04:55 PM
  1. #1 air noise under boost
    GT Level Member hourang's Avatar
    commerce, mi
    am i supposed to hear an air rushing sound under high boost? i only hear it when i really get on it. sounds like air escaping or something. maybe its normal. also seems like the power just isnt there when i floor it, half throttle feels great. how do i know if i have belt slip? i know my s/c belt is bad which i will be replacing as soon as i can.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  2. #2 Re: air noise under boost
    Donating Users kfish's Avatar
    Ohio
    if you have belt slip yous hear a squeeling sound.
  3. #3 Re: air noise under boost
    commerce, mi
    Quote Originally Posted by kfish View Post
    ah ok no belt slip then.
    -Jeff
  4. #4 Re: air noise under boost
  5. #5 Re: air noise under boost
    commerce, mi
    vacuum leak or something of the like.
    i was thinking that too but it doesnt show the normal signs of a vacuum leak. it runs and idles beautifully. could it be something with the pvc system and high pressure?
    -Jeff
  6. #6 Re: air noise under boost
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    its possible i guess. go ahead and change out the pvc anyway.maybe u hear the air befor it enters blower. if u heard air after blower, u'd have moree problems immediately.
  7. #7 Re: air noise under boost
    commerce, mi
    Quote Originally Posted by badbrad View Post
    yeah im not familiar with these cars enough to say if its normal, it could very well be. my last supercharged car was a mustang where the exhaust was way louder. so im not really sure. i just thought someone might know.
    -Jeff
  8. #8 Re: air noise under boost
    Dec 2008
    hueytown, alabama
    do u still have the stock intake system on it or have u changed it yet?
  9. #9 Re: air noise under boost
    commerce, mi
    yeah its stock. i tried messing with it and it looked like everything was there, including the top and bottom silencers.
    -Jeff
  10. #10 Re: air noise under boost
    Dec 2008
    hueytown, alabama
    i kno on a bmw i had, the intake (factory)had little chambers attached to them. i knocked one off and it baffled me till i finally found the chamber in my yard....crazy germans
  11. #11 Re: air noise under boost
    the PCV will rattle if its good. shake it in your hand. its a cheap part.
  12. #12 Re: air noise under boost
    London, Ontario, Canada
    I've got the same thing in my car wondered if it was an issue or not. My sound is coming from almost under my seat I just guessed it was air passing through the resonator. If you find another answer let me know maybe I have a problem.
  13. #13 Re: air noise under boost
    GT Level Member Joe m's Avatar
    mesa,az
    if you have a boost gauge hooked up on the pillar the hose connecting to the gauge could of fell out and you would hear the sucking/blowing sounds from it.
  14. #14 Re: air noise under boost
    commerce, mi
    no boost guage. sound is coming from pass side front area.
    -Jeff
  15. #15 Re: air noise under boost
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    this very thing happened to me and it stopped after i had my exhaust done. turns out the downpipe flange to the tailpipe was rusted and once we cleaned all that up it went away.
    2000 Daytona GTP(aka the slow fwd GTO)
  16. #16 Re: air noise under boost
    commerce, mi
    you know what the more i think about it, it could be an exhaust leak. i noticed my exhaust has a bigger leak now and the air noise i dont hear as much. i think the hole got bigger and doesnt make an air escaping noise. we will see when/if i fix the exhaust.
    -Jeff
  17. #17 Re: air noise under boost
    MO
    do you have the A/C running?
    <brandonl2000> LMAO D!!
  18. #18 Re: air noise under boost
    commerce, mi
    Quote Originally Posted by ZR1Vette09 View Post
    nope
    -Jeff
  19. #19 Re: air noise under boost
    MO
    Quote Originally Posted by hourang View Post
    nope
    just making sure. never know when it's that little "d'oh" moment.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. New noise..again..help?
    By BwolfGT in forum General Tech Discussion
    Last Post: 11-03-2009, 09:47 PM
  3. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  4. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
