Thread: Top Swap Wiring
Results 1 to 6 of 6
  1. #1 Top Swap Wiring
    SE Level Member AlldaySteve1's Avatar
    Flint MI
    Hey guys, I'm new to the site but I wanted to read up on as much on the top swap as possible before posting my questions. I had a 2000 GTP that ran a 13.14@106. I forgot to put antifreeze back into it this winter so the block cracked. I just picked up a GT and want to bolt up my supercharger with mods. I plan to go use ZZP's MANIFOLD ONLY to take advantage of higher compression, which brings me to my quesion...
    -What is the deal with the wiring?
    -Some state just add "connectors and be done with it" What are these?
    -Would I be better off using my 2000 GTP PCM with wiring harness to save my HP tuners Credits?
    -How does leaving the bottom nipple of the bypass achieve a "Vaccum" system?
    Thanks for your time!
  2. #2 Re: Top Swap Wiring
    you need the MAP harness adapter only. the BBV can be run on vacuum only by leaving the lower line off the solenoid. this will allow full boost without the stupid PCM interfering. you cannot use your GTP PCM because of the transmission files.
  3. #3 Re: Top Swap Wiring
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    well, I would use the gtp computer if you have credits on it. I would assume that you're using the gtp trans? I would even use the gtp wiring harness so you don't have to mess around buying an adapter for the map sensor.
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  4. #4 Re: Top Swap Wiring
    Cambridge On
    Hey there i'm new to the site and i'm going to do a top swap. I'm confused about the MAF. Do i have to get a different MAF and harness or can i modify mine some how?
  5. #5 Re: Top Swap Wiring
    nope its all the same.
  6. #6 Re: Top Swap Wiring
    Oct 2008
    Northern Illinois
    MAFs are the same. Fastkatt and I started with a GTP stock tune combined with the GT trans files as a base, then tuned the **** out of it from there.
  1. wiring help.
    By chunky in forum Audio, Security & Visual Electronics
    Last Post: 11-22-2009, 03:09 PM
  2. Wiring or???
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-19-2009, 10:30 PM
  3. Amp Wiring
    By jjwitty in forum General Tech Discussion
    Last Post: 07-23-2009, 09:21 PM
  4. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
