Thread: HELP Installing Pulley
Results 1 to 19 of 19
  1. #1 HELP Installing Pulley
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I am trying to get ths pully back on using the Pulley puller sent to me by 3800 Performance and I broke the 2 little bolts that hold the large bolt in place. I have about a quarter inch to go. I am using grease to keep everything moving for the bolt the Shaft is not moving I am using a bar to keep tension on the Belt so the shaft does not move. these are breaking right in the middle so it is not backing out on me. WHat do I do. Should I go and try to get a few more of these at the hardware store I guess is there a kind of harder metal I should look for.
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: HELP Installing Pulley
    Naugatuck CT
    so noones got any comments on this????
  3. #3 Re: HELP Installing Pulley
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by jacobmh27 View Post
    You need to be more patient for help than three hours, champ.
    How are you cracking bolts? Are you using the proper anti-seize on them? I am not sure what you are describing, but I would back them out and grab replacements from the parts store.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: HELP Installing Pulley
    Naugatuck CT
    Was not tring to be rude or anything. Just had very limited time bacause today I am in Texas and I was trying to get it done yesterday. My car is down right now tried to take the pully off and back on again same results. Broke 2 more of those bolts and crushed one trying to get the oully off. Should it be this hard. I am going to try again on Friday. If anyone has anything to help. I am running out of ideas.
  5. #5 Re: HELP Installing Pulley
    in a house
    I wouldn't worry about him. Can you take a pic, might be easier to help you as Im not understanding your issue. From what I gather the pulley is only going on halfway and then snapping bolts? Where is this pulley from? At this point I would consider draining the s/c oil and pulling off the snout and then taking it to a machine shop and let them deal with it before you damage the shaft.
  6. #6 Re: HELP Installing Pulley
    Naugatuck CT
    might be a good idea. I am not home right now and I am in Texas I will be home friday to try again. I will take a picture then.
  7. #7 Re: HELP Installing Pulley
    Naugatuck CT
    Ok so I guess I am a Dumb ___. When I got the Pulley I took it out of the Box and on the box it says This side away from pulley. Well I guess I put it back in the Box upside down and so I was trying to put it on backwars. So when I Took it back off and Flipped it over. It went on. Imagine that. Lesson Learned I guess.
  8. #8 Re: HELP Installing Pulley
    Largo, Florida, United States
    oh my god.. >.>
    Your the guy that calls Tech Support saying
    You: "MY COMPUTER WON'T TURN ON HELP ME HELP ME!"
    Tech: "Is it Plugged in?"
    You: "oh...."
  9. #9 Re: HELP Installing Pulley
    Outer Space
    oh my god.. >.>
    You: "oh...."
    Pot meet Kettle.
    02 GTP 13.6 @ 100mph - SOLD
  10. #10 Re: HELP Installing Pulley
    Quote Originally Posted by Lawngoose View Post
    Pot meet Kettle.
    I don't do dumb**** like that.
  11. #11 Re: HELP Installing Pulley
    Outer Space
    riiiiiiiiiiiiiigggggghhhhhhhttttttttt.... cause you know all about gp's and your a jedi-master...
  12. #12 Re: HELP Installing Pulley
    oh my god.. >.>
    You: "oh...."
    Dude, your so ignant.
  13. #13 Re: HELP Installing Pulley
    Wichita, KS
    Hey...it could of been worse like this guys GenIII that showed up to me last week.
    For what ever reason, they thought it would be a great idea to finish the job of installing the pulley with a hammer.
    Bolt removed was a grade 8, 5/16" size. Ya...thats a big cry away from a M8.
    Not sure who played mechanic here...but they should have all their tools taken away. I was able to use my press to get the pulley off, but that snout is toast.
    Atleast jacobmh27 is asking for help.
    ~F~
  14. #14 Re: HELP Installing Pulley
    Topeka, KS
    Indeed. Sounds like he got it figured out. I'm sure he is enjoying his new found power too.
  15. #15 Re: HELP Installing Pulley
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Pot meet Kettle.
    LOL
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  16. #16 Re: HELP Installing Pulley
    Naugatuck CT
    I would be injoying the new power but I am waiting for my computer to come from Overkill it will be here this week and now I am on my way to China for 3 weeks so the car is parked and I did take a few spins in the car but stayed off the gas I do not want anything to go wrong till I get the new Computer. there was nothing on the pullyey telling me what way it goes on so I had a 50/50 shot and as always I picked the wrong way. It looked like the right way to me. But I did not use a hammer and I took my time and stopped when I knew something was wrong. it is on now and THANKS FOR SOME PEOPLE ON HERE HVING MY BACK lol Thanks
  17. #17 Re: HELP Installing Pulley
    Wichita, KS
    I got your back bro!
    Send me a post card from China!
    ~F~
  18. #18 Re: HELP Installing Pulley
    Banned - Busted For Scamming
    Feb 2009
    That looks about right.
  19. #19 Re: HELP Installing Pulley
    Naugatuck CT
    In Japan waiting for my next flight I will find a postcard and post the Pic. I can not wait to get home and drive the car with the new computer. Just driving the car easy with the new pulley I felt a big difference in the Low RPM's
